stuff
Then again, someone has to show the n00bs what NOT to do. You do serve a purpose after all!
So how's the wife?
Exactly what makes you think you need to run a narrowed rear for a 100 shot? I mean seriously. That's ******* hilarious!
You are obviously out of the loop here. I'm sure you are used to it though.
So how's the wife?
Gregrob,
Corey by far had the best pricing might even be cheaper to send him your motor. Plus they sponsor the Shootout
Rgr that.
355
13.9:1 Compression (roughly)
E85
CP Pistons
Compstar H beams
Pro-gram splayed 4 bolt mains
H bearings (Clevite / ACL)
21° TrickFlow Heads ported by Lloyd Elliot
Ported Intake Manifold by Lloyd Elliott
TrickFlow PR's, Guide Plates
Ultra Pro Mags 1.6
Either TF beehive or Patriot Dual Springs
Moroso Billet Oil Pump
Canton Oil Pan
1 7/8 Headers
58mm or MonoBlade TB
Nitrous Outlet Plate Kit
Dual Walbros
Mallory 685
48lb injectors
Built T-56, already done, will faceplate and do Viper main/output if it breaks
S60 TrueTrac 4:30s
3" Strange Chromoly DS
UMI Adj TA, LCA's, SFC's,
Undecided K member
DA Afco or Strange Rear Shocks
Undecided adj front shocks
Centerline Telstar drag wheels
28" MT ET Drags
Tune by me
Cant comment on the cam other than it's going to be "healthy".
But Gregrob **** sounds like a nasty *** build.
I keep deciding between keeping mine a street car or a race car and at the moment leaning to keep it a street car.
at 6000 ft you can get times then head down here to sea level and rip that **** up!
Then with da nawwzzz it should be a tad better than high 10's. But we'll take it one step a t a time and see what happens.
