can no tune effect missfire
Old Feb 22, 2011 | 03:06 PM
LigHtEmUp01's Avatar
Angry can no tune effect missfire
i just got my 355 with pp heads small cam running. it has no tune and i drove it around the block and when accelerating the rpm needls was bouncing a little and it was misfiring. it starts up and idles with no issues can this be caused from the stock ecm not being tuned?
Old Feb 22, 2011 | 03:22 PM
RamAir95TA's Avatar
Not having the proper tune can cause all sorts of problems. Regardless you still need a tune, so I would load up a mail-order tune and see if that helps.
Old Feb 22, 2011 | 09:03 PM
im starting to think i should. but i wanted to get it dyno tuned by a place that near by me but he said i need to drive it 500 miles or so but since it runs like **** im thinking about getting a mail order tune
Old Feb 22, 2011 | 09:20 PM
RamAir95TA's Avatar
What do you mean "you need to drive it 500 miles?" Because it's a new motor?
Avoid them then... Running a new motor on the dyno is perfectly okay if done properly.
Old Feb 22, 2011 | 09:26 PM
BigD383lt1's Avatar
Are you running pp stock heads... what plugs? I had similar issues with mine changed the plugs and the gap problems went away...
the guy told me since i have steel rings that i should break it in longer around 500 miles or so? inn my opinion its ready to go after turning over on a machine for 4 hrs
Old Feb 22, 2011 | 09:27 PM
yes stock heads with delco platinum plugs gapped at .50
