Driving with no o2 sensors?
so time has run out and my o2 extensions are not here. I need to drive 2 1/2 hours through a mountain pass.
Is the car gonna get me from A to B Just on what the pcm knows? or am i up **** creek without those extensions?
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
the front two are 4 pin flat connectors and the rear two are 4 pin square connectors. while it may be possible to repin the rear harness to the front connectors i think its more difficult. plus im not sure how the order of the wires need to be changed going from the square to flat. I already have the list of pins on the pcm so just swap bank 1 front and back and bank 2 front and back. this will only be tempory if it does work. the limiting factor here is whether or not the harnesses for the rears will re-rout properly to the fronts
no the rear sensors will get mounted in the headers and temporarily be used as fronts. this is because the harness for the rear sensors is long enough it might reach the header bungs without needing extension. once i get my extensions, the front o2's will go back in the front bungs and i will repin the pcm back to stock. the rear o2 sensors will not be used at this point because im putting an ORY in.
And LSWHO, rear O2s are heated too, jackass.
LOL you'll noticed at the top of this thread my puntuation isn't horrible. by the bottom the effort was gone. I try my best.
I don't mind explaining things. I get so much help on here that I like to give back the best I can
Hey douchebag. That's why it was in question form. Illiterate pathetic bitter old man.
If you paid attention, I asked a different question about O2s just before it, clearly not me acting like I know. God damn your a POS today. Learn to read.
