what has to be done for 383
Old Feb 22, 2011 | 05:08 PM
bizerk1's Avatar
Default what has to be done for 383
what has to be done for me to take my lt1 and make it 383 or 396. what will need to be replaced and changed on the car. has anyone done this here. how much does it cost for it and is it worth the cost
Old Feb 22, 2011 | 06:31 PM
jester1614's Avatar
for a 383 or 396 the motor will have to be bored as well as clearanced for the stroker crank, that requires new pistons and rings as well as the machine work,
a new crank (forged is highly recommended over cast) will need to be purchased, as well as new cam bearings ,main bearings, and rod bearings, stock rods can be used perferrably with new rod bolts.
with all the work on the bottom end you will need a new cam and ported heads as well as new springs, pushrods, rocker arms, guide plates possibly as well if you want the car to perform
Old Feb 22, 2011 | 07:06 PM
97Z28SS's Avatar
You're better off buying a complete forged rotating assembly (crank,rods, pistons, rings and bearings) then you'll need to have the block machined (bored, honed, decked and splayed 4 bolt billet caps installed). You'll also need to have the block clearanced in the panrail area and balance the rotating assembly, plus you need to get your heads ported and a matching cam.
Old Feb 22, 2011 | 07:55 PM
lifeisgood's Avatar
go with golen. for the money its a better idea
Old Feb 22, 2011 | 08:11 PM
BOLO's Avatar
I would highly recommend Clayton Racing Engines in Bartlett, Illinois. Talk to Corey Clayton, he'll set you up. In fact, he's a sponsor here.
Old Feb 22, 2011 | 08:20 PM
RamAir95TA's Avatar
IMO it's not worth it unless you have the funds to invest in a good heads/cam deal at the same time. Leaving the valvetrain stock with a 383 bottom end will do you absolutely no good.
Old Feb 22, 2011 | 08:57 PM
nitrous2fast's Avatar
well you might gain 40 lb/ft.... lol
Old Feb 23, 2011 | 09:53 AM
quik95lt1's Avatar
u never know he could be pulling stumps out of the ground with his camaro lol
