New Setup Is Acting Very Homo........!!!
then just when i thought it couldnt get any worse..........car starts to run hot!!!..fluctuated to 240 then down to about 200 then a little more driving it hit 260+!!!
i bled the system some more temp didnt drop at all...has a new thermostat but its a autozone t-stat....radiator is fairly new...anyway to tell if waterpump
The egr, and the 02 sensors showing up means that in the computer its still trying to read that information, being that there not there its gonna run crazy rich.
something with that pink wire is causing the car to NOW run lean.
REASON for the heat.
rich runs cold.
lean runs hot.
both cases are only FOR EXTREME> and if your burning **** up and running 260 its definitly lean.
DO YOUSELF a favor.
take the damn pcm out. and call them.
and or use the ocm your buddy has.
Your going to **** up your car even more trying to make something that is FAIL work.
i have continuity to ground on the black wire
it has 5v reference from the pcm
but 0v on the pink 12v supply for it....
what fuse do i need to be looking at?
and out of curiousity if this doesnt have voltage what else doesnt?
i have a 96 z28 m6 if that helps....
BTW, specifying what you are driving helps a lot when you are asking maintenance advice.
also i had my fans set for 195 and 210....should i have set them a little lower?
More than likley your coolant crossflow tube or the banjo bolts are clogged if you can't get the air out. The best way to bleed these cars when they are clogged is to get the front end up in the air and bleed it that way. My crossover tube was clogged and when I tried to bleed mine I had the same problems with it trapping air in the system. When I put in my 383 i made sure that damn crossflow pipe was clear and it bleed so easy. Car was level and all you have to do is just fill it and start it and top it all off. The crossflow pipe is a real pain in the *** to get to and a bigger pain in the *** if it's clogged. I am a cheap bastard so I spent a week working on that thing and the banjo bolts with brake cleaner, carb cleaner, compressed air and a dremel just because I was too damn cheap to buy another. I did have to buy new seals for the banjo bolts. Most guys go to home depot and buy fittings and to the auto parts stores for rubber line to replace the crossover pipe. I think you can still buy them though. Not sure what it costs though.
