is my opti bad
Old Feb 23, 2011 | 11:03 PM
hot-trans am's Avatar
Default is my opti bad
hey a have a 96 trans am a4 wit header and bbk tb my car runs good till 4000 rpm then it bog out and miss could it be the opti car has 121000 miles on it
Old Feb 23, 2011 | 11:26 PM
onephatZ28's Avatar
I would say yes. if you get a new one just get one from GM.
Old Feb 24, 2011 | 12:02 AM
Fazz73jr's Avatar
Check your fuel pressure. could be your pump diying or cloged fuel filter.
Old Feb 24, 2011 | 08:47 AM
how would i check my fuel pump to see if it bad, also the guy i got it from had a msd box hook up to it. but wen i got it i unhook it. people told me they mess up the opti is that true
Old Feb 24, 2011 | 12:04 PM
mguidry629's Avatar
To check fuel pump and most other fuel problems: $40 mechanical fuel pressure guage from an auto parts store and screw to the schrader valve to monitor fuel pressure.
If pressure is good, then you can eliminate fuel delivery problems.
Old Feb 24, 2011 | 10:06 PM
ok thank i will be doing that wat psi is good for my car
Old Feb 24, 2011 | 10:39 PM
SoxXpupPeT's Avatar
check everything before you go ahead and dump aload of cash into it.
Old Feb 25, 2011 | 10:07 AM
well the car has new msd 8.5 wires and it runs ok till 4000 rpm then bog and miss it had a msd box hook up went i got the car but i unhook it thinkin it was the problem wat else can i check
Old Feb 25, 2011 | 02:46 PM
onephatZ28's Avatar
check the ignition coil and Ignition Control Module
How to
http://shbox.com/coil/coil.html
Old Feb 25, 2011 | 02:55 PM
onephatZ28's Avatar
replace your fuel filter
how to
http://shbox.com/1/fuel_filter.html
check fuel Pressure
how to
http://shbox.com/1/4th_gen_tech2.html#fuel_gauge
IF ALL IS GOOD THEN I WOULD SAY NEED NEW OPTI
hope this help you man good luck
Old Feb 28, 2011 | 09:20 AM
everything else is good so i going to get a opti thank should i hook back up the msd box or not like poeple say it make the opti bad
Old Feb 28, 2011 | 10:59 AM
davorocks's Avatar
everytime i go to the j/y i pull control modules from LT1's. before i spaced it off the head i would burn one up every few hundred miles, having symptoms VERY similar to yours. ever since i spaced it i have had no problems (knock on wood.)
Old Feb 28, 2011 | 12:49 PM
1961ba427's Avatar
Will a bad opti always throw a code?
Old Feb 28, 2011 | 01:02 PM
like idk i bought the car the way it is and it has 121000mile but they put a msd box on it and then the car runs ok till u give it 1/2 gas then it bog at 4000rpm i dont know how to check the ICM but i keep that in mind
Old Feb 28, 2011 | 01:03 PM
Old Feb 28, 2011 | 02:04 PM
davorocks's Avatar
Originally Posted by hot-trans am
it bog at 4000rpm the ICM but i keep that in mind
mine drove great untill i gave it more throttle. i didnt pay attention to the rpms, just that it did not run good under a good load. its worth a shot if you can get one cheap. they are not cheap new.
Old Feb 28, 2011 | 03:16 PM
1961ba427's Avatar
Wasn't hi-jacking....I was thinking a reply to my question may be of some benefit to the OP. Seems like a reasonable point to a post titled: IS MY OPTI BAD?
Old Feb 28, 2011 | 04:25 PM
thank im think ima see if i can get one from the j/y and try it
Old Feb 28, 2011 | 08:18 PM
onephatZ28's Avatar
IF YOU GET A NEW OPTI GET A GM BRAND, DON'T GET ONE FROM EGAY. i got a Accel from summit and it fried at 100 mile. once again good luck
Old Feb 28, 2011 | 10:14 PM
tricked94camaro's Avatar
chandler motorsports
By Brett Foote | 2026-06-04 05:00:17
