Started new engine. Runs for only 3 seconds.....
Also I have converted over to OBD1 and changed the knock sensor. Was I suppose to do anything else? Would it hurt if I put my OBD2 PCM back in just to see if it will stay running? The OBD2 PCM has a tune for a completely different cam, but I figured if I didn't WOT I would not hurt the engine. Correct?
I won't be leaving the OBD2 PCM in, just trying to see if the OBD1 PCM is bad.
