solid roller
257 266 @.050 106lsa .640 lift intake and exhaust with 1.6 rockers. I have the exact figures if you are interested. The cam was installed but never used as I went a different route with the engine. $200 shipped.
T oanswer your question. It will need to be LT1 specific cam as I believe the front of the cam is a little different.
valvetrain? do the lifters collapse or something?
if so i thought theyre were companies out there making stronger parts for high revs?
Stud mount. IMO I don't think shaft mount is necessary unless going over 7000rpm.
Able to run a far more aggressive lobe and the valvetrain will remain stable.
Yep....that cam is in the vicinity of mine......little lower on lift though
Jesel 1.6 Shaft Mounts
Whats in it for a rear end??
