Power source when engine is running only
Old Feb 27, 2011 | 04:00 PM
gregrob's Avatar
Default Power source when engine is running only
Is there a relay that gets triggered only when engine is running?
I want to wire the EWP so that it runs when the engine is running, with also the ability to turn it ON and OFF manually with a switch.
Old Feb 27, 2011 | 04:03 PM
Black94Z28's Avatar
Fuel pump? Not sure if this would work or not, but the fuel pump is turned on and remains on with the key in the run position...
Old Feb 27, 2011 | 04:18 PM
gregrob's Avatar
Im wanting something that will not trigger the relay until the engine starts.
Old Feb 27, 2011 | 04:20 PM
Black94Z28's Avatar
Well if you have an on/off switch, couldnt you just keep it off until start up or whenever you wish to turn it on?
Old Feb 27, 2011 | 04:49 PM
gregrob's Avatar
I could, but I dont want the liability of forgetting it. I want it to be on by default, then manual on, and manual off.
Old Feb 27, 2011 | 06:24 PM
Wicked94Z's Avatar
hm.... lemme look at my wiring schematics and try to come up with something easy rather than electrically complicated
Old Feb 27, 2011 | 06:34 PM
93QWKZEE's Avatar
I think the fuel pump does run only as the engine is started although it does turn on for 2 seconds when key is in ON position then turns off so that might work. But im not sure you would want to tap into the power from it,it may draw to many amps for the relay and could possible fry the wiring,the fuel and water pump all in one shot. But that just my 2 cents and I'm not 100% sure. I want to know how aswell if anyone else is doing it without issue. I have a csr pump being shipped as we speak.
Old Feb 27, 2011 | 06:40 PM
riceburnerZ28's Avatar
You could buy this kit it can make things a bit easier.
http://www.summitracing.com/parts/PRF-50106/?rtype=10
Old Feb 27, 2011 | 06:43 PM
gregrob's Avatar
You wouldn't want to run the main power wire to the pump from any other source and take a chance on overloading that circuit. You would simply use that source to trigger the relay, then have its own dedicated power source to the battery...
How will that accomplish what I'm trying to do?
Old Feb 27, 2011 | 07:07 PM
05HD's Avatar
See if you can turn on a relay from the oil pressure switch.
Other than that, the fuel pump relay is as close as it gets.
Old Feb 27, 2011 | 07:14 PM
muddyjimmy's Avatar
I would agree with using the fuel pump trigger. That seems like the best approach to getting it done, and what I plan to do with mine.
Old Feb 27, 2011 | 07:16 PM
gregrob's Avatar
Good idea. We will look into that.
Old Feb 27, 2011 | 08:09 PM
noice's Avatar
I don't know if I like the oil pressure switch idea. I used the fuel pump signal to start the EWP, but if you are looking for a signal to start your EWP after the engine starts, put a timer on a signal from the Alternator maybe?
Old Feb 28, 2011 | 11:38 AM
93QWKZEE's Avatar
gotcha, keep us posted on what you end up using I will most likely do the same. I hate waiting for parts but when they come I'm like a little kid opening a present.
Old Feb 28, 2011 | 03:06 PM
Z28Camaro30Ann's Avatar
Calvin, when you figure out how to do this, let me know. I am tired of having the pump on at key on. Draws too much power off the battery.
Old Feb 28, 2011 | 03:16 PM
litch2004's Avatar
IIRC I used the abs relay and fuse location and just repined it. Used the original power source of the key in the on passion. It's only on with the key in the on position but the engine doesn't have to be running. That way I can still let it cool the fluid down with engine off. It has a manual cut off switch as well as my fans. Works great for in between runs.
Old Feb 28, 2011 | 05:46 PM
ss.slp.ls1's Avatar
I would just tap into an ignition + source that is on when the key is on. It won't hurt anything if the pump engages a few seconds before the car is actually fired.
Old Feb 28, 2011 | 06:48 PM
Fazz73jr's Avatar
Why not use the fuel pump wire to trigger a relay for the ewp? This way it wont burn up the already weak fuel pump circuit. It will come on for a few seconds with the fuel pump to prime then shut down.
Old Feb 28, 2011 | 07:10 PM
sweetbmxrider's Avatar
Yup, grab it from the alternator. That's how remote car starts disengage the starter once the engine fires.
Old Feb 28, 2011 | 08:17 PM
gregrob's Avatar
