Power source when engine is running only
Old Feb 28, 2011 | 08:43 PM
fex77k's Avatar
I have mine wired to a relay and triggered off the fuel pump/PCM wire.
Old Feb 28, 2011 | 11:03 PM
Fazz73jr's Avatar
Originally Posted by gregrob
Haha, read fail on my part... sorry. I was on my phone at work.
Old Mar 14, 2011 | 01:42 AM
Z28Camaro30Ann's Avatar
Question...Sorry if it is kinda dumb but I started thinking about it and am confused now.....
I have the hotwire kit for my Walbro Fuel Pump, so my FP gets it's power from the back of the alternator...I am considering doing this on Tuesday BUT I thought about it...Isn't the back of the alternator hot ALL the time because it gets a direct line from the battery?? I thought the one-wire connector was the only one that was hot when the engine was running because of the fact that it is the line that charges the battery once the car starts, but ALL the power from the battery is connected to the back of the alternator...right? If this is right, then the hot wire from the back of the alternator to the FP would be a constant hot and would not work to activate the EWP when the engine starts...am I wrong?
Sorry if this is kinda retarded, but I dont understand the wiring much yet..working on it lol.
Old Mar 14, 2011 | 01:57 AM
Wicked94Z's Avatar
i'm confused as to what you're trying to do? lol if you need some sort of custom wiring solution I can help ya out
Old Mar 14, 2011 | 02:01 AM
Trying to have the WP OFF when key is off, OFF when key is on/Engine off (2 second run is ok), and ON when the engine is running with the ability to turn the pump on manually when key is off.
Right now mine is set up so that the pump comes on with the key on and no manual switch, but that draws alot of power off of the battery if I am sitting with just the radio on and my car is a DD.
Old Mar 14, 2011 | 03:07 AM
Wicked94Z's Avatar
I could make a board with engine on/off logic but the easiest way would be to have a switch for turning the pump off
Old Mar 14, 2011 | 08:42 AM
I dont want to have to worry about turning my pump on and off all the time, only for when I am at the track wanting to cool it down before the next run, and I dont want to have to have the key on for that cause it draws too much power and will kill the battery too fast.
All I want to know is if I am right or wrong as far as the wire from the hotwire kit on the alternator, and if I am, what wire would be an acceptable one to trigger the EWP WITH the Fuel Pump
Old Mar 14, 2011 | 08:56 AM
Wicked94Z's Avatar
If you want to tap into the fuel pump enable wire you can do that, it's green/white off pin 7 of your Red pcm connector. Otherwise there's no "spliceable" options to trigger a relay the way you want.
I can set you up with a switch and harness for the EWP. It'd be OFF-Normal-ON. I could integrate your cooling fans into the ON portion for track use. Just don't touch the switch and it'll operate how it does now with key on. LED indicators can be added as well for safety!
Old Mar 14, 2011 | 10:43 AM
sweetbmxrider's Avatar
The hot wire lead on the back of the alternator is always hot, yes. You could tap into the pcm ground for the fuel pump relay to operate your ewp relay.
Old Mar 14, 2011 | 11:25 AM
Ok, that is what I thought! I will just tap into the FP Relay wire to the PCM. Thanks!
Old Mar 14, 2011 | 11:39 AM
gregrob's Avatar
That's what you need to . Use the same wire that triggers the fuel pump relay. The one of the back of the alt is the main feed to the pump
