Car is F'd, what to do?
I have helped people pull transmissions, engines and rear diffs out in the street in the past as well. It isn't the most pleasant place to work but it is possible in a jam. Hell, I helped a friend change a head gasket in a random parking lot in Texas after we drove from south Florida (and had to fix the damned car to make it back). So, no space to work on it isn't a good excuse if you are properly motivated!
But if you do decide to part it out i'll take that upper center console off your hands
If you were interested in selling it, I'm sure a TON of guys on here (including myself) would be interested in picking it up from you and fixing it. The problems you have with it right now are minor.
They keep saying it and I will repeat it.. It's just nuts and bolts..
Learn on it man, just do it and have some patience.
My main concern is that my driveway isn't flat. It's not at a very steep angle, but it's still not flat. I'm trying to figure out the safest way to get this thing up in the air and pull everything out. Will jack stands do the trick? Should I try to hunt down some cinder blocks? I don't know how high I need to get this thing off the ground for the transmission to clear, or how to hold it up there in a secure position, but I'd rather not have my car drop on my face. I don't think my fiance would be too happy about that. That's my biggest problem. Everything else isn't an issue. I either have or can get all of the tools I need.
