what it takes to run 10's
Old Feb 16, 2004 | 04:21 PM
Slow TA's Avatar
Default what it takes to run 10's
what all does it take to run 10's in a lt1?
Old Feb 16, 2004 | 04:27 PM
Rob 94Hawk 319's Avatar
about 550 rwhp.
Old Feb 16, 2004 | 04:41 PM
Vendetta's Avatar
It will take you traction/weight reduction, and a power adder (f/i or n20) or more cubes.
Old Feb 16, 2004 | 05:16 PM
squinn's Avatar
In my NA car I'm going 9.9's at about 3250 with 442 RWHP, but yet the ET show 630 fwhp. For 10's NA a reworked stock short block, hyd roller in the 240's range, ported stock lt1 heads will work, car wight at about 3400. 10's should not be to hard at that point, and this should be streetable.
Old Feb 16, 2004 | 08:57 PM
BizZzatch350's Avatar
Moderator
A nice 355 on gas, thats what I want to do. Just build a good solid motor capable of doing 11s na, then go 10s on spray.
Old Feb 16, 2004 | 09:28 PM
Elysian's Avatar
9.9 is smokin' fast for a NA 370. Gotta be a cool car. Out of curiousity, what kind of suspension are you running? And what do you mean by "streetable?" Do you mean it CAN be driven or that it doesn't lope like a biatch around town?
Old Feb 16, 2004 | 11:23 PM
squinn's Avatar
Stock type suspension that I built, something like thw wolf setup, I'v run this set up for years. That hyd roller I speak of was not that bad on the street, loped a bit. I really think the soild roller I have now sounds milder
Old Feb 17, 2004 | 11:17 AM
Aries's Avatar
boltons and a 200 shot
Old Feb 17, 2004 | 08:16 PM
RacinLT1's Avatar
with bolton's and a 175 shot i was running 11.02........if the trans didnt break,i woulda been in the 10's.
Old Feb 24, 2004 | 06:04 PM
aram's Avatar
Originally Posted by Rob 94Hawk 319
about 550 rwhp.
Maybe for you full weight M6 guys with stock suspension.
Old Feb 24, 2004 | 07:37 PM
SSC5R's Avatar
WARNING! Bad Seller Alert
It's going to take the cubic dollar$$$ That's all it comes down to.
Old Feb 24, 2004 | 09:38 PM
Have you even been to the drag strip with your f-body?
Old Feb 24, 2004 | 11:17 PM
fastta's Avatar
I've seen many LT1 guys get into the 10's with not much more than 400 RWHP. 550 RWHP should get you deep into the 10's.
Old Feb 25, 2004 | 10:23 AM
Elysian's Avatar
Has anyone ever hit 10's on a stock shortblock? . . . that lived to race another day?
Old Feb 25, 2004 | 08:32 PM
RacinLT1's Avatar
wel i was damn close to the 10's on a stock longblock....about 25 11.0-11.1 runs close. hundreds of runs in the 11.2-11.3 range also.
quite a few guys have gone 10's had the shortblock live,just gotta make sure the tuning is right.
Old Feb 26, 2004 | 12:55 AM
Z-Dreamer's Avatar
I'd recommend this https://ls1tech.com/forums/showthread.php?t=136030 and you wouldn't need to spray either!
Mark
Old Feb 26, 2004 | 01:13 AM
fastta's Avatar
Definitely a unique motor!
Old Feb 26, 2004 | 10:58 PM
Z-Dreamer's Avatar
Yes, it's that and about 100 lbs. lighter than an iron SBC too!
Mill the solid domes on the pistons flat for about a 11 to 1 comp, add the right cam, induction and exhaust system and you could make 600 HP on premium unleaded!
Mark
