door hinges
Old Mar 12, 2011 | 07:29 PM
93z28ltone's Avatar
Default door hinges
anyone else having problems with there door hinges
Old Mar 12, 2011 | 08:27 PM
RamAir95TA's Avatar
What problem are you having chief?
Old Mar 12, 2011 | 08:56 PM
93z28ltone's Avatar
same thing that most people have with the hings on a 4th gen getting worn out and the door sagging a little which makes it hard to open and shut the door cause it rubs against the bottom
Old Mar 13, 2011 | 01:50 AM
carlos64030's Avatar
Sooooo... are you looking for a solution, or you're just posting to make conversation?
Old Mar 13, 2011 | 01:35 PM
leadfoot4's Avatar
This "problem" has been ongoing since the 2nd gen cars!
Big, long heavy doors on two relatively small hinges. Hinge bushings are a "maintenance item".....
Old Mar 13, 2011 | 05:05 PM
93z28ltone's Avatar
Posting to make conversation I know how to fix it
Old Mar 13, 2011 | 05:50 PM
jester1614's Avatar
as far as i know there are no 4th gen bushing kits, I have always just replaced the hinges. they are pretty freakin easy if you have help and are willing to remove the front fenders.
what i do is i use a permanent marker and trace around the hinges (for location later) and then remove the door from the car, set the door down on a stand. and replace the hinge, then reverse and check the door fitment. and reinstall the fender
Old Mar 13, 2011 | 06:33 PM
IronOutlaw's Avatar
Well my door is sagging and I need to know the easiest way to fix it. A guy I work with said I could replace the door pins in the hinges.
Old Mar 13, 2011 | 06:39 PM
jester1614's Avatar
i have found lower hinge pin kits, but nothing for uppers
here is a link
http://www.dragtimes.com/parts/Chevy...267003475.html
Old Mar 13, 2011 | 08:54 PM
93z28ltone's Avatar
My 98 t/a use to sag really bad and now my 93 Camaro is starting to also
Old Jul 28, 2011 | 01:24 PM
ws6taguy's Avatar
Is there a way to get the bushings out of the door hinges?
Old Jul 28, 2011 | 06:34 PM
killagt's Avatar
I remember my lt1 having a loud pop when u open all the way and close it, it does not make pop sound when u just open half way and close it, this normal ?
Old Jul 28, 2011 | 07:24 PM
94lt1white_bird's Avatar
no way to replace the hinge/bushing just get a new hinge assembly with everything intact from a car being parted out that is in decent shape this is what i did a week ago and she feels nice and tight again
Old Jul 29, 2011 | 01:51 AM
01ssreda4's Avatar
Often the hinges have no play in them. When lifting the door, the play will come from the fiberglass door itself where the hinge bolts. This fatigues and stretches over time. The solution would be to reinforce this area of the door itself.
