Whats needed to run e85?
Old Mar 15, 2011 | 08:16 PM
Wicked94Z's Avatar
^^^this^^^
Old Mar 15, 2011 | 09:18 PM
killerz97's Avatar
I think im going to wait to run e85 for now. I just cant find anybody to tune it. Once more people start tuning for e85 i will definitely convert.
AChotrod's Avatar
What would happen if you ran the motor on E85 and a stand alone on c16 for spray?
Old Mar 15, 2011 | 09:28 PM
Wicked94Z's Avatar
you woudnt have any sort of a/f marker to tune from, which can be helpful for a new setup on the dyno. everything would be off plug readings
Old Mar 15, 2011 | 09:51 PM
AChotrod's Avatar
Thats what I thought.
Old Mar 15, 2011 | 10:24 PM
gregrob's Avatar
Why bother, E85 and nitrous go together just fine.
Old Mar 15, 2011 | 10:40 PM
05HD's Avatar
This is wrong.
You can mix up as many different types of fuel as you like. Lambda is still Lambda and you still have a best power rich and a best power lean.
It also doesn't matter what your wideband reads out in A:F units for. It is still telling you Lambda if it works.
Old Mar 15, 2011 | 10:41 PM
05HD's Avatar
A lot of tuners have tried it and sworn it off as garbage.
Old Mar 15, 2011 | 10:44 PM
gregrob's Avatar
http://www.dynotuneusa.com/
Old Mar 15, 2011 | 10:57 PM
05HD's Avatar
I would be interested in your 60# injectors if I can find somebody to tune my car. Also any other ideas for a fuel pump besides the a1000 and dual walbros. I will only need to be able to support 500hp on e85.
Get one of those 340 LPH "Aeromotive Walbros". I forgot the name or part number Aeromotive came up with for it, sorry. It will work great at that power level as long as you don't ask it to make too much pressure (AKA make sure injectors are big enough).
Old Mar 16, 2011 | 07:42 AM
1961ba427's Avatar
Originally Posted by 97pontta
for you guys running E85 once you are setup to run E85 is this the only fuel you can run? There are not an abundance of E85 pumps in my area and was wondering. I assume you cannot run regular premium fuel once setup for E85?
I've wondered about this^^^ too. Would you need a spare PCM with a tune to run normal gas to swap in? I know bi-fuel vehicles are on the road everywhere and "sense" what fuel is in, and the pcm compensates with different tunes. If one could swap pcm or tune to swap between fuel types, would you be able to keep the same injectors in and compensate for the flow through the tune, or would the injector size difference between the two be too great?
Old Mar 16, 2011 | 10:15 AM
  #32
9transam6's Avatar
I must admit this seems like alot of money spent to get little HP is there a particular reason why you would go thru all this trouble to use a fuel that robs power and miliage? or is this a just because type build?
Old Mar 16, 2011 | 03:00 PM
  #33
Wicked94Z's Avatar
Originally Posted by 05HD
This is wrong.
what lambda do you shoot for?
Gas wants 12% enrichment, E85 wants 20% depending on the motor combination of course. So what enrichment do you shoot for on each particular shot of nitrous?
Old Mar 16, 2011 | 03:04 PM
  #34
Wicked94Z's Avatar
Injector size wouldn't be too much of a problem, you might be giving up a little throttle response and idle quality on gas, but low-z injectors would help there.
You can run a "race" motor on the street with E85, instead of paying $12+ per gallon for race gas. I've NEVER heard of E85 robbing power, keep that bullshit to yourself instead of mis-informing people.
Old Mar 16, 2011 | 05:43 PM
  #35
9transam6's Avatar
well thats why I had a ? at the end I wasnt miss informing people I was asking a question. So before you talk unessecary BS understand what Im saying. And yes It will rob power from these hybrid gas factory motors my dad has 1 and he says it clatters and bogs out everytime he uses it. And the loss of mileage pretty much makes up for the difference in price.
Old Mar 16, 2011 | 05:48 PM
  #36
05HD's Avatar
Somewhere between 12 and 20 percent, depending on how much of your total fuel is coming from E85 and how much is coming from C16. E85 is already a minimum 15 percent and up to 30 percent gasoline so this isn't really adding any overall complexity to the tune.
Old Mar 16, 2011 | 05:51 PM
  #37
05HD's Avatar
There is something wrong with your dad's hybrid. Fuel economy will be reduced but power will at least remain the same as gasoline, given everything is working correctly.
Old Mar 16, 2011 | 06:05 PM
  #38
96TransAmboosted's Avatar
Wicked how much for the 60lb ers????????
Old Mar 16, 2011 | 06:06 PM
  #39
nitrous2fast's Avatar
Tuning for E85 is very simple... And tuning for E85 with nitrous is simple also. Make your tune for the E85 non-nitrous. Then add the nitrous and proper fuel for your ratio you are running and watch the A/F on the dyno or on your wideband. 8.7/1 aka .88 lambda would be a great start. To properly size the fuel jet, its just a physics equation.
Old Mar 16, 2011 | 06:23 PM
  #40
355z28's Avatar
105 octane...makes it easy to run high compression, cheap race fuel.
I gained over 20rwhp and 10rwtq switching. I have a 12.3:1 motor with e85 we could get more aggressive with the tune and gained some power. E85 can support an engine thats 13-13.5:1 so imagine gaining the 15-25 horse with compression on top of that. if the setup is based around it its actually probably the biggest bang for your buck vs $10 a gallon race fuel.
not only did I see a power gain, I dropped 15* engine temperature.
and as far as highway milage for example my OLD 355 engine would only get 18mpg on the highway with 93 octane pump fuel. Now with my 383 on e85 I get 16mpg, and worse ive seen is 14 on the highway (depending on the weather)
Only thing Ive ran into is that E85 tends to like a little bit more timing pulled with nitrous then 93 pump gas.
If I were to just have a heads and cam stock shortblock car I wouldnt be running it. But given what I have I wouldnt do it anyother way.
