LT1 Procharger
It would be a time bomb to me though...
save the money that you would have initially spent on just buying the fi set up and build a very streetable and yet devastatingly powerful 383-396. You can get into a full forged bottom end for less than 3k(would spend that for fi also) buy a custom ground cam and have your stock heads ported and flow benched so you have a good idea about the cfm you're pushing and then build your exhaust to match your needs. Finally if 430-470 rwhp is not enough get a nitrous set-up set on a 150 hit and watch the dyno scream to ~600rwhp.....way too much for the street butoh so fun
Like said above you can run it being smart with all the right parts to go with it and a spot on tune. The issue is how long is it going to last? A day, week, months, years? You just never know and is it really worth all that money and you have to second guess every time you hit the throttle is she going to handle it? I was down this road and if i was still deadset on going FI i would build a forged bottom end around 10.5:1 with stock head cc's and when you have the cash to with the blower buy a set of AFR or TFS 62-65cc heads which will bump your compression down to a safer rate while being n/a for a short in the meantime. Its all up to what you want but if you wanted to go both ways and have a bottom end built once that twice this is the way to go.
Build it right the first time!
