yikes!! cant read codes
Old Mar 18, 2011 | 06:09 PM
LigHtEmUp01's Avatar
Default yikes!! cant read codes
i have an ses light that keeps coming on and i have tried 2 code readers and none of them will connect to the computer. why could this be? all the prongs look good.
Old Mar 18, 2011 | 06:27 PM
any ideas....
Old Mar 18, 2011 | 06:30 PM
RamAir95TA's Avatar
What code reader are you using? VERY few readers have the capability to read a 95 due to the hybrid OBDI PCM/OBDII connector. Even most parts stores can't scan them. Your best bet for scanning is a low cost AKM cable and a laptop.
Old Mar 18, 2011 | 06:33 PM
i used an autozone one and an oreilly one both different i dono the names. my friend said he has a better one that we can try but if not what do i need to scan it on my laptop?
Old Mar 18, 2011 | 06:39 PM
LT1559's Avatar
aldlcable.com...order the cable, download the free program, buy a power converter for your laptop(optional) and you're good to go
Old Mar 18, 2011 | 06:42 PM
ivan_key's Avatar
Normal code readers won't read 95s, I have a 3000 dollar snap on scanner that I have at work that reads them fine
Old Mar 18, 2011 | 06:48 PM
thats interesting i guess because some of them are obd1?
Old Mar 18, 2011 | 06:51 PM
RamAir95TA's Avatar
All 95s are OBDI, but the ALDL connector is a 16-pin D-shape connector commonly used for OBDII. 95s are funky like that.
Old Mar 18, 2011 | 06:56 PM
[QUOTE=RamAir95TA;14657426]All 95s are OBDI, but the ALDL connector is a 16-pin D-shape connector commonly used for OBDII. 95s are funky like that.[/QUO
oh that makes sense then!
Old Mar 18, 2011 | 07:09 PM
shbox's Avatar
Any OBD-I code reader/scanner will work on a 1995. You just need the right cable or adapt a 12 pin cable like this.
Old Mar 18, 2011 | 09:53 PM
67goatman455's Avatar
i actually tried this 2 days ago and couldnt get it to work.....
Old Mar 18, 2011 | 11:23 PM
MasterTomos's Avatar
My local oreilly's scanner works just fine for my '95
Old Mar 18, 2011 | 11:25 PM
shbox's Avatar
When all the pieces of the puzzle are right it does work.
OBD-I scanner, correct pins connected, no reason it should not work.
Old Mar 19, 2011 | 12:01 AM
SexyTransAm's Avatar
a good ol tech II works just fine lol
Old Mar 19, 2011 | 02:13 AM
BIG_T's Avatar
same here
Old Mar 19, 2011 | 11:38 AM
yea it was just the wrong cable i put my friends scanner on it with a dif cable and it connected thanks guys.
Old Mar 20, 2011 | 08:25 AM
maybe it was the fact that it was a OBD-I/ OBD-II scanner.
Old Mar 20, 2011 | 09:26 AM
shbox's Avatar
My handheld is a I/II scanner and it works fine. Something in the setup or connection could be at fault.
Old Mar 20, 2011 | 05:43 PM
Bullit95T/A's Avatar
i agree I bought the exact scanner that O'reaillys uses and it works for my 95 you got to use the blue connector with the AUTOXRAY scanner..
