Traction bar help
Old Mar 21, 2011 | 09:56 PM
smith35's Avatar
Default Traction bar help
Ok so i have a 95 t/a lt1 an i was wondering if its possible to put traction bars on it? I havent sene an 4th or newer gen f-body with them. But i need somthin to make my rear end stop spinning at launch. Or r there any tricks to it? I did have drag radials on it an it didnt catch traction till 3rd gear, so please let me knw what yall have
Old Mar 21, 2011 | 10:05 PM
Formula96's Avatar
I am assuming 6 speed, u spinning 1 tire or both?
Old Mar 21, 2011 | 10:19 PM
bigj2717's Avatar
The thing that keeps f-bodies from getting traction is the stock stamped steel parts. When I first put in my adj panhard bar it fixed everything. Lower control arm and shocks help too
Old Mar 22, 2011 | 07:21 PM
97Z28SS's Avatar
I have a set of red BMR lcas for sale for $80 + shipping, pm me if you're interested. You also need an aftermarket torque arm.
Old Mar 22, 2011 | 07:24 PM
nitrous2fast's Avatar
if its lowered... lca relocation brackets are a must for proper suspension geometry.
Old Mar 22, 2011 | 08:20 PM
tbag_skywalker's Avatar
Pretty sure the only thing traction bars do is eliminate wheel-hop on cars with leaf spring suspensions.
What brand of drag radials are you running? I've got BFG's and I can spin the **** out of them-- my car probably isn't even making 300rwhp.
I've also got an old set of Hoosiers on a different set of wheels that almost dead-hook. Last time I launched on those, my differential started singin' and it wasn't long till I needed a new set of gears and bearings.
If you've already got Hoosiers or Mickeys, try upgrading your suspension.
Start with cheaper stuff first-- relo brackets, subframe braces, rear LCA's. Then eventually get shocks, springs, and a torque arm.
By Brett Foote | 2026-06-04 05:00:17
