FML! bent 8 rods today
I do have a question though;
I hear people say "180 off" or "180 out" from time to time. But I don't understand how it matters.
That crankshaft spins twice for every time the cam spins once. The crank doesn't care which
cycle it's on .. it does the same thing to compress as it would to exhaust. So if you line up dot to dot,
how does this cause damage? It sounds like the cam sprocket went back on somewhere other than dot to dot.
<-- NOT MINE, random google images picCan happen if your pistons jam the valves back up into the head because
a) timing chain skips, breaks or is set wrong
b) you overtighten your rockers
I'd rather bend a pushrod than break a valve or damage a piston anyday.
1. Why did you remove the timing cover to change an opti?
2. The gear fell off and you want us to believe the cam magically aligned 180 degrees out of phase?
With heads, push rods and springs on a car you don't simply turn a cam with your finger. To get a cam to turn to align 180 degrees out of phase doesn't just happen. Sounds like a story but not one I believe.
Good luck
Good luck
I do agree that you cannot turn the cam or crank easily at any point on an assembled engine. Unless its worn the *** out and no valve train in installed. LMAO Cant wait for further explanation.
There seems to be many mysteries in this section so a cam turning itself is nothing out of the ordinary.
Good luck on valves not being bent.
Thankfully.
