Balancer question
Old Mar 27, 2011 | 01:45 PM
starbucks's Avatar
Default Balancer question
Ok guys here is my question. I had a motor built about a year ago and I didn't upgrade to an ATI like I wanted to. Well long story short I plan on ordering an new ati balencer but the old balencer looks like it has ben balanced before by the machinist. I was pretty sure that all lt1s were internally balanced but looking at the balencer that is currently on there it looks like it has been balenced.
Old Mar 27, 2011 | 02:09 PM
nitrous2fast's Avatar
LT1 are externally balanced.
Old Mar 27, 2011 | 02:12 PM
James Montigny's Avatar
A stock LT1 is externally balanced at the rear (flywheel/flexplate)
The balancer (front) should be neutral.
Since you had this custom built, it may have been internally balanced.
Check with your builder (or build sheet).
I run a neutral flexplate for that reason.
Additional Reading;
https://ls1tech.com/forums/lt1-lt4-m...-balanced.html
https://ls1tech.com/forums/lt1-lt4-m...balancing.html
Old Mar 27, 2011 | 03:17 PM
starbucks's Avatar
Oh I see. Thanks for the help guys I'll get with the engine builder to see what needs to be done.
