Balancing.
Old Apr 30, 2008 | 12:08 PM
projekt70chevelle's Avatar
Default Balancing.
From what I understand, the lt1 (95 model) is internally balanced. I am in the process of doing a budget rebuild and I plan on balancing the rotating assembly. A couple of the shops i spoke to just need the rotating assembly, where as one says they also require the hub/pulley and clutch/flywheel. I have also heard that the hub and flywheel are neutral balanced, if thats the case then i don't see how that would effect the balance of everything else. Also keep in mind i am doing a 6 speed swap as well (if that has any effect on it).
What have you guys done with your builds?
Old Apr 30, 2008 | 12:16 PM
Formula350's Avatar
The hub is supposed to be neutral balanced, but bringing in the flywheel would be a good idea. In all honesty, I'd bring it all to them, just so we know everything is working in harmony.
Old Apr 30, 2008 | 12:17 PM
C_Rules's Avatar
mine is currently getting balanced as we speak. i have a 94 and switched to a lightweight crank and a nuetrally balance flywheel.
Old Apr 30, 2008 | 12:42 PM
leadfoot4's Avatar
The LT-1 crank hub doesn't have a keyway in it from the factory, even though the crank has provisions for keys. Having one broached in it (the hub) might be a good idea.
Old Apr 30, 2008 | 12:44 PM
YodiBrodi's Avatar
the LT1 is externally balanced. the damper is TYPICALLY, but not always, neutrally balanced. the flywheel is not. i have heard of ppl having stock cranks internally balanced though so since you're getting your engine rebuilt i would look into having that done. it simplifies things, alot.
Old Apr 30, 2008 | 12:46 PM
Stroked96Bowtie's Avatar
Its your motor, the machine shop will typically balance it however you like. Some people jsut prefer internally balanced motors while others think its easier to keep stock style balancing. My motor maintains stock style balancing.
Old Apr 30, 2008 | 02:33 PM
NSTIGATR's Avatar
ok so when i order my 355 rotating assy i want to order the crank that has internal balance at the front and external balance at the rear for a 1 piece rear seal..correct....and have it balanced stock style? this is also for a 6 speed
95 z28 lt1 m6
Old Apr 30, 2008 | 09:24 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
You have a few choices.
To clarify, the motor is externally balanced, but only at the rear.
The harmonic balancer is neutral balanced.
You can either have the crank made for this configuration or you can go with a true internally balanced motor. This requires the stock flywheel to have the counterweight removed & the flywheel rebalanced, or better yet buy a zero balance flywheel for the 1pc. seal crank for the best method.
Old Apr 30, 2008 | 10:41 PM
BALLSS's Avatar
1. stock LT 1 is externally balanced. the hub is neutral balance and the flexplate or flywheel is "weighted" (aka external balance
2. if you do get your rotating assembly "internal balanced", you will need to get a "neutral" balance flexplate or in your case flywheel. You can have a stock flywheel zero balanced for about $40 or buy a neutral balanced one
