Hitting 400rwhp in an LT1
I don't take the software too seriously either but it starts the "400lbs" at around 2200 or 2300. and at 2000 it's at least like "380 lbs." aside from when it starts it also shows it carries it further than a few other profiles. If in the least the blasted thing shows how the various profiles tend to be like or what their torque/HP curves pattern like in theory. Basically it looks like the big cam with the smallest lowend sacrifice. Ballparking HP levels of bigger ones but shakes hands with torque a little stronger. But again it's just a wannabe computer dyno, what's important is the pattern it reflects(a very good1) cuz that can't be too far off. The differences in real life numbers or output like you suspect will vary.
Anyway, after having looked around on CZ28.com I found a guy pushing 400rwhp with the TN-230HL 230/236 duration, .598"/.608", 112lsa (Combination Motorsports). Question: does anyone know if I would have to fly-cut pistons with this cam? If I don't, I think I'm pretty much sold on it. Obviously, CM would probably be able to answer that, I just haven't had time to call them yet.
Weird. Seems that the 224/230 cam with ported heads setup is snakebit for some reason. I can think of four people that immediately come to mind that have been having trouble with them, yourself included. I had it and made 375/363 on an initial tune, but then dropped major compression on two cylinders.
I'm going with a 355 forged rod and piston, Eagle ESP cast crank, and swapping everything over, and getting a custom cam. Should be nasty, well over 400. I may even go with the 383 if I can find the extra $500 for the crank.
http://web.camaross.com/forums/showt...hreadid=233687
