Hitting 400rwhp in an LT1
Old Apr 5, 2004 | 11:06 AM
  #61
TWS's Avatar
TWS
Originally Posted by Fastbird93
Honestly, with the 224/230 on a 112* LSA, a GOOD set of stock ported heads, and a set of 1.7 rockers, you may make it to 400 with everything right. That's what I was shooting for before I found my bottom end took a crap.
I have "only" comp cams 1.6 RR's. My stock heads have been thoroughly ported and polished, but the MAC mid-length headers are choking them (at least that's the theory). Even if I pick up 20 RWHP ( a stretch?) by switching to long tubes, I still won't hit 400.
I don't have flow numbers for the heads. Had a guy with a good reputation do a hand port and polish on them in his own garage, so it wasn't a fancy-schmancy shop with a flow bench etc.
Old Apr 5, 2004 | 04:22 PM
  #62
Fastbird93's Avatar
I seriously doubt you're going to pick much if any peak HP and TQ by switching to long tubes. Under the curve you'll probably stand to pick up a bit, but top end, probably not.
It's possibly with that cam, but EVERYTHING has to be well matched.
Old Apr 5, 2004 | 06:21 PM
  #63
97M6Formula's Avatar
I am only 20 hp/tq away from 400 with home ported heads and intake stock throttle body and mods in list thats na by the way
Old Apr 5, 2004 | 06:37 PM
  #64
Fastbird93's Avatar
You got a dyno chart??? I"d like to see that.
Old Apr 5, 2004 | 07:26 PM
  #65
I cant find it im looking for my other one to where I dynoed 350/350 with huge 11 degrees of KRI have taken out many zo6s and lost by one car 1.5 cars to my friends heads/cam ls1 when he was on a et street with hals and a 9inch and me on my ten bolt street tires and stock susp...heres a vid of his car but this isnt the race im referring to...... http://cpowell8384.tripod.com/sitebu...files/sean.wmv
Old Apr 10, 2004 | 03:49 PM
  #66
Elysian's Avatar
UPDATE: Ok, this really blows. My car was running great for about a day. I've figured out why it is running like complete a$$ . . . 8 of the 16 COMP-R lifters have collapsed and are not recovering. I initially thought we might have installed them wrong. But the car ran perfect for a day! How the hell can that be? More-over, when we installed them, the rockers were adjusted exactly to the specifications given by COMP's tech-line. The guy at COMP said the lifters were probably defective from the get-go. I'm thoroughly disgusted. These were supposed to be the best hydrolic lifters money could by, and in less than 50 miles, they're shot. How they hell do you get a box full of parts that are HALF bad!!?? What kind of quality control are they running - or is there any? COMP says if I send them my lifters back they "might" give me some new ones, provided they decide the lifters are in fact defective.
Let's assume for a second that I was the one who screwed something up: I adjusted the pre-load on each lifter to COMP's specs, I have the right length push-rods, is there something else I could have missed?
