Pulled Headers Off... **PIXXX*
Old Mar 30, 2011 | 02:02 AM
1BigBird3's Avatar
Exclamation Pulled Headers Off... **PIXXX*
Hola Fbuuuuuuuuuuuuuuuuuuds!!!!
Been SLOWLY getting back into the game and this is where I'm at:
Pulled off the Headers to have a looksee and as you can see each valve looks a little different.
Let me know what you guru's think from experience and would recommend for next action to take.
Also if you could explain cause and effect on Cylinder 6 and 4 I'll be greatly appreciated. Cylinder 7 and 8 look like a cause for concern. Thoughts?
Motor is just your basic 355 H/C combo. Did a rebuild about 20k miles ago. Runs like a champ except for a KR spasm every now and again. I just let it sit for a spell and decided to pull it and have some fun.
Thanks advance!
-Ruben F.
P.s. I *lost* the pic of Cyl 1 but it looks EXACTLY like Cyl 2 for reference.
Attached Thumbnails Pulled Headers Off... **PIXXX*-dscf0514.jpg   Pulled Headers Off... **PIXXX*-dscf0515.jpg   Pulled Headers Off... **PIXXX*-dscf0516.jpg   Pulled Headers Off... **PIXXX*-dscf0517.jpg   Pulled Headers Off... **PIXXX*-dscf0518.jpg
Old Mar 30, 2011 | 02:15 AM
riceburnerZ28's Avatar
To me it's possibly a few bad valve seals. What does the plugs look like?
Old Mar 30, 2011 | 12:34 PM
94transbird's Avatar
Looks like a lot of carbon build up. I agree with riceburner. Need to know what the plugs look like.
Old Mar 30, 2011 | 04:49 PM
the_merv's Avatar
Veteran: Air Force
How old are your Fuel Injectors? OPTI? Wires?
You are getting a normal burn in some of them, and hot in others.. either the whole car is lean and it's hitting good in some and shitty in others cause you a Wire problem..or everything is good and some of the Injectors are crap.
Thats where I'd be lookin..
Old Mar 30, 2011 | 06:19 PM
SoxXpupPeT's Avatar
i agree with whats been said. check the physical layer first. and with the easiest. plugs/wires. then valve seals.
