obd1 - obd2 swap??
I am using the full harness from the 97 including the column gauges.
I know this will be an unpopular answer here but for a stockish motor 1 5/8" is better for average power unless you spin say north of 6500rpms. Here is some testing one of the Impala SS guys did. http://home.comcast.net/~mmsmith17/ look in the "tech" section. He thought that on his heads/cam/juice/ car the 1 3/4" 4into1s would be best, turned out the 1 5/8 Tri-Ys made the most average power and he would have to spin past 6800 to take advantage of the extra HP the quads offered at higher rpms.
The "ideal" thing in your situation would be to get a new knock sensor, for a '94-95 F-body. That way the PCM stays stock. You also only need to run the front O2 sensors (don't need the rears any more).
If you don't want to buy a knock sensor, you can buy a 3.9k resistor from Radio Shack, open up the PCM, and carefully solder it on the back side of the circuit board between Blue 22 and Blue 1 (it will lay down between the row of pins - but use some insulating piece of electrical tape wrapped around the resistor to prevent shorts).
I converted my OBD1 car to OBDII at one time. The OBDII PCM has better automatic transmission control - the OBD1 PCM simply could not handle my 3500 stall converter. It'd freak out and send me in to "soft shift to third" limp home mode. The OBDII computer never did that.
But stuff for OBDI PCMs is less expensive (scan tool, programming tools). That's the biggest reason for it. Consider if you want to program an OBDII PCM, you're looking at AutoTap to scan it ($300-ish), LT1Edit for OBDII or Tunercat (haven't checked lately, but let's say $400-ish). Versus $90 for a cable, plus free scan software, plus $90 tunercat. Darn near the same thing, but for 1/3 the price.
Now, if you buy an OBD1 PCM from a parts store, odds are very good that it will NOT have the right program in it. You'll need to find the right program on the 'net (or send me an email / PM and I'll email you one, I have all of them). You'll need to match it up to your combo - M6 transmission. And keep in mind that not all 16188051 PCMs ran a 350ci motor... there was a 262ci L99 that used it as well (Caprices). So the program that's in the PCM could be for that motor... in which case, your motor won't run very well at all (heh, been there, done that). But that PCM can be reprogrammed to run your motor just fine. Did that too.
For a sleeper I would say the Crane 227 cam 210/224 nice mid and upper rpm gains but docile as stock, you want a little lope go up into mid to upper 21X range on the usual 112. Any cam swap will require pcm reprogramming and new valvesprings with roller rockers being a good idea as well.
