two codes someone plez help
Old Apr 1, 2011 | 10:30 AM
97 texas ta's Avatar
Default two codes someone plez help
My car is throwing a timing ref a to few pulses and a ic ckt not toggling or grounded code. Can any one help plez
Old Apr 1, 2011 | 10:36 AM
Gojira94's Avatar
1) Take the ignition control module off and have it tested at Autozone, etc. Have them test it several times in a row to get it warm so it will fail if it's weak. Replace if needed.
2) Clear the codes and see if the res. pulses code comes back. If it does, you may need an opti...
Old Apr 1, 2011 | 10:45 AM
We just replaced both opti and icm that's Wat sucks. Do u mybe have any other ideas? Mybe
Old Apr 1, 2011 | 10:52 AM
Gojira94's Avatar
Did you replace the harness piece that connects the opti to the main harness?
Old Apr 1, 2011 | 10:54 AM
Big Al's Avatar
Are you using the stock coil? Was the DTC code 42?
Al
Old Apr 1, 2011 | 11:16 AM
Gojira94's Avatar
Al
Believe he's OBD2, based on his user name. 1351 or 1361 for the ICM code, either 0323, 0372 or 1371 for the distributor pulse code. OP, what are your exact codes?
Old Apr 1, 2011 | 11:35 AM
Its po372 for the timing ref and p1361 for the ic ckt and I think when we were bleeding the radiator some coolant got on that connector that goes on top of the distributor
Old Apr 1, 2011 | 11:41 AM
Gojira94's Avatar
ok, unplug that harness piece and clean it out, make sure there's no coolant in the connector on the body of the distributor as well. See if you've got any corrosion, etc on either end of that harness piece. Look at the end on the pass. side of the intake as well. It clips onto the EVAP purge solenoid bracket; gray flat 4 pin connector. If it looks dirty or corroded you can clean it to some degree, but a replacement would be smarter. If you just got it wet, clean it off and let it dry and it should be ok.
Don't forget to clear the codes and test again...
Old Apr 1, 2011 | 12:15 PM
Ok thank y'all ill let y'all know how it goes thanks again
