My cammed LT1 is a dog on the dyno...HELP!
#61
#63
#66
So I finally got an update on the slow LT-1; took it to the old Pontiac, now GMC/buick dealership that my buddy is a service manager at and had one of the better mechanics who knows what he's doing adjust the valves/rockers; he did it turning over the motor doing each cylinder at a time right in front of me so at least I have an idea of how to do it now. He said a few rockers were a little loose but nothing major to cause that much power loss. After driving it, it feels a little better but not 320 RWHP fast...I'm going to drive it this week to see how bad the gas mileage is; I'm thinking the lack of power and mileage has got to be related. I'm either going to have to race my own other car with my friend driving on the highway or take it to Z-Max dragway in a couple months to see if it's making the power it should by the trap speed. In the meantime, I still want to get a leak down test done for my peace of mind and to eliminate a compression issue; what's a decent price for this on a LT-1?
#67
Damn...it's one thing after another with this car; I get the rockers adjusted and a header gasket blows out! FYI don't use the gaskets that come with pacesetters...they suck. I put in new AC delco O2's because one of my old ones was "lazy" when dyno tuned and it STILL gets 9-10 MPG....I've gone through a half tank of $4.10 premium in 75 miles
**** guzzles gas like a blown big block except none of the power
I can't afford to keep driving the car till I get some answers on WTF is going on. The guy that rebuilt the motor is gong to take off my headers, do the leak down test, and change all the plugs to NKG TR55's next week....all for $150 which is not bad at all for the time it would take; another shop quoted $250. Any advice or recommendations on what else to look at? Pretty much eliminated a fuel issue due to the AFR on the dyno chart all the way to 6500, all ignition parts replaced recently (except opti...car is on it's 3rd at 145K), all sensors replaced or working normally, computers been tuned TWICE, exhaust/ cold air intake are brand new, cat hollowed...no kinks ect, compression is questionable until next week;....where else should I be looking?
What would you do if was your car? (I'm not burning it or selling to some 16 year old yet
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
#68
I'm guessing it's in the tune. So... who tuned it? If you said it i'm not searching the thread to find it out.
#69
Who tuned it, how much timing are you running and how much knock are you getting? I had to pull 10-15 degrees down low and that allowed me to add some up top and I gained CONSIDERABLE power doing so.
#70
It's been tuned by Bryan from PCM for less and a local dyno shop Sigma six dyno services in Concord NC. How do you tell how much timing it's running? The dyno tuner said my car was not pulling timing and it actually took MORE timing than usual to make power than a normal LT1. It's not getting any knock I'm aware of; I got a LT4 knock module in the computer already and I only run 93 octane.
Get a local guy to scan your car around town.
#76
I installed my LE2 h/c 8 years ago and my cam was off by just under a 1/2 degree. I didn't feel it was worth me buying a multiple keywayed timing set. Car still made over 400@ the wheels so I was happy.
Good luck
#78
That would be true unless the clutch is only slipping at higher rpms, Ive had that happen even with the wheels in the air and it acted normally driving around town (but that was a centerforce and we know how those things are)
#79
so this has been going on how long and you haven't raced your other car yet? that is the first thing i would have done after getting the car off the rollers. at the very least confirm it is down on power and your assdyno/other dyno is not just reading low for unknown reasons.
although, i'd guess the lsjuan would be pullin on the lt1 regardless of how well it was or wasn't running
![Nut swinger](https://ls1tech.com/forums/images/smilies/nutswinger.gif)
#80
I know it sucks to take down a new engine but thats what needs to be done. I would do a compresion check on it first though.
