ltcc question
Old Apr 5, 2011 | 09:15 PM
1BadAsZ's Avatar
Default ltcc question
do you still have to have a good opti for this to work? i just developed a high rpm miss for some reason and have been considering just swapping but if i have to use a good opti i donno if its even worth the trouble
Old Apr 5, 2011 | 09:20 PM
RamAir95TA's Avatar
You still need a functioning optical sensor, yes. The LTCC eliminates only the high voltage portion of the opti.
Old Apr 6, 2011 | 09:36 PM
1BadAsZ's Avatar
The car cranks and runs, actually drives. It's just high rpm it doesn't like all of a sudden. All I did was clean the maf and change from tr6's gapped@35 to tr55gp's gapped@50 n now it won't rev all the way to the shift point
Old Apr 6, 2011 | 11:25 PM
RamAir95TA's Avatar
Switch the old plugs back in and install a dirty MAF.
No seriously...if it was running fine go back to the way you had it. Throw on another OEM MAF from a friend or something, switch the plugs out, and see if the problem goes away.
Also, if the plugs/MAF are the problem, there's no reason why the LTCC would fix it. You need to START with a properly running engine for the LTCC to work properly.
Old Apr 7, 2011 | 09:42 AM
glassjaw1704's Avatar
Have your ICM tested.
Old Apr 8, 2011 | 09:12 AM
1BadAsZ's Avatar
Well I guess I found one of my problems. My Dang coil is arcing off of its own bracket. My last msd was doin it so I bought another one now its doin it. I guess Imma just go back to stock cause this is the 3rd msd I've had go bad
