ls coils
Old Apr 8, 2011 | 05:52 AM
S10Wildside's Avatar
Originally Posted by defaultexistence
Anyhow been awhile since I looked but heres the link, doesn't look
used.. Matter of fact it says "built from scratch" ...
http://www.sspwiring.com/LS1_Wiring_Harness.php .... Is it a deal ?.. U be the
judge
Apples vs Oranges. That $375.00 harness does not include:
  • 4th gen F-Body layout or lengths
  • transmission wiring or connectors
  • OBDII diagnostic connector
  • 4th gen F-Body C100 connector and wiring
  • 4th gen F-Body C105 connector and wiring
  • 4th gen F-Body C210 connector and wiring
  • 4th gen F-Body C220 connector and wiring
  • 4th gen F-Body C230 connector and wiring
  • 4th gen F-Body specific firewall grommet
  • 4th gen F-Body alternator connector and wiring
  • LS1 PCM connector dress covers
  • finished loom or tape
  • and so on
And after zooming in on the website's harness image...
  • no reinforced Delphi ground ring terminals (generic alternative)
  • incorrect color scheme for GM schematics
  • bulky wire (that's not TXL...which is used in the original harness)
  • missing some connector seals (new connectors include the seals)
  • modified coil harness connector
  • wrong crank sensor connector (shown with 24x PCM, but 58x crank connector)
  • no cavity plugs in unused PCM connectors
I'm not saying the $375.00 harness won't be functional (for its intended application...other than the wrong crank sensor connector), but I am saying you are comparing apples to oranges and $375.00 is nowhere near what it costs for materials, labor, etc. for a new 4th gen LT1, 4th gen 24x LT1, or 4th gen LS1 engine harness.
