Uh oh, look what Daddy did....
Old 04-07-2011, 07:51 PM
cumminsram06's Avatar
I heard the same thing, you would have to remove the dash, maybe that's to keep the heat though? There's no way you could smash that box with the motor in there though right? It looks way too deep under the cowl to get a good swing at it. Isn't the heater core in that box or is that in the dash?
Old 04-07-2011, 08:15 PM
flyinZ's Avatar
Those TB's are sweet. I've got a monoblade too.
Old 04-07-2011, 09:02 PM
05HD's Avatar
Evaporator core for the a/c is all that is in that monstrosity. With engine in, a piece of pipe at the end of the hammer would be your friend.
Old 04-08-2011, 12:54 AM
gregrob's Avatar
Originally Posted by robsquikz28
Brian lol
Greg, is that a monoblade?
Yep, AS&M Monoblade
Originally Posted by TravisMcGill2000
looks great man. im ready to c this beast at the shootout
Me too! I'll be there either way tho
Originally Posted by fex77k
You should make a few with the bulge, I'll take one for sure.
I'll see what I can do! I talked to a friend about making a few but hes pretty busy so I think I'll buy one of the BMR / Madman / etc ones and modify it myself for now.
Originally Posted by 93QWKZEE
Hey have gregrob have you run into any issues with the throttle cable with the n2o plate and TB? I have the same AS&M TB but am running a NOS N2o plate and the throttle cable is a little short maybe a 1/8 to short??? If you have any problems let me know how you work it out.
I haven't ran the throttle body yet. I got it for the new build. I'll keep updated how it works out though. I imagine you could space / bend the bracket forward to compensate for only 1/8" ???
Originally Posted by 1badzee
Nice work on the heater box! How much of it were you able to take out? I was under the impression that you have to remove the dash or some ****.
Nope, no need to remove the dash. As HD stated the AC core is the only thing in the part of the plastic box that protrudes into the engine bay. Find whatever means that floats your boat of smashing it into a million pieces, remove core. Trim jagged edges flush with the firewall with a cutoff wheel, airsaw, whatever, vacum up all the leavings and your finished
Old 04-08-2011, 01:01 AM
fex77k's Avatar
Originally Posted by nitrous2fast
You want his bulging plate?????!! hey whatever man...to each his own...
J/K lol
No I'm good on that.
Old 04-08-2011, 01:03 AM
fex77k's Avatar
Alright, I probably need to do it.
Old 04-08-2011, 01:25 AM
gregrob's Avatar
I'll let you know what we come up with.
Old 04-08-2011, 01:29 AM
speed_demon24's Avatar
Just curious what the reason for an S60 over a 9" is, especially with how cheap fab 9's are becoming.
Old 04-08-2011, 01:37 AM
gregrob's Avatar
Didn't want to wait months for a MWC Fab 9. Got a good deal on the Strange. They're very efficient for a big ring gear. The ring gear is actually bigger than a 9. The 9 can be built to be stronger, but I believe out of the box the S60 is stronger though.
Pretty much boiled down to price and availability. The Fab 9's are nice as well and I wouldn't hesitate to run one.
Old 04-08-2011, 11:16 AM
sweetbmxrider's Avatar
Why not make your own delete panel? Just use cardboard as a template since you are going to have to cut a hole for the hc in and out. Then you can paint it to match your firewall.
Old 04-08-2011, 11:22 AM
camar0corey's Avatar
Nice on the upgrades!
Isn't price always a driving force? I ended up going with a Moser 12 bolt, because I managed to snag one for $1750 with an Eaton posi and Denny's driveshaft.
Old 04-09-2011, 12:41 PM
  #32
BIG_T's Avatar
awesome! in for updates of ur heater panel
Old 04-09-2011, 02:20 PM
  #33
1badzee's Avatar
Awesome, good to know! Any worthwhile weight savings from this? I know most people do it for the cleaner look and all.. Build is looking pretty sick man.
Old 04-10-2011, 01:16 PM
  #34
itSSlowZ28's Avatar
i'd take one of those panels...
Old 04-17-2011, 12:44 AM
  #35
gregrob's Avatar
LPPs coated by Swaintech are here
Will post pics when they're painted
Old 04-20-2011, 12:42 AM
  #36
gregrob's Avatar
Steve does amazing work! www.pro-jectioneng.com
Old 04-20-2011, 01:02 AM
  #37
alexcoreas's Avatar
Beast bro
Old 04-20-2011, 01:21 AM
  #38
robsquikz28's Avatar
whats all the relays and wiring to?
also do you need a a/c heater core box delete plate? I have one for sale
Old 04-20-2011, 02:08 AM
  #39
gregrob's Avatar
Nitrous ewp 2 step bottle heater line lock etc etc
Yes I need one
Old 04-20-2011, 02:52 AM
  #40
Turnin20s's Avatar
I thought the ac delete plates from Madman/UMI/BMR/whoever bolt in from the inside and won't work on the outside. I could be wrong but I thought I read that.
Build looks good man, keep it up
Quick Reply: Uh oh, look what Daddy did....
