Looking for an easy way to plug the oil filter by-pass.
Old Apr 8, 2011 | 01:23 PM
Big Al's Avatar
Default Looking for an easy way to plug the oil filter by-pass.
Title says it all...
Anyone done this?
Al 95 Z28, LT1 with metal in the oil from cam failure.
Old Apr 8, 2011 | 01:59 PM
RamAir95TA's Avatar
Anyone done this?
I have no clue what you're talking about.
Old Apr 8, 2011 | 02:18 PM
Tony Shepherd's Avatar
I do it on all my builds.
Press the pressure (BYPASS) valve out, tap, and plug. Screw the plug from the top of the adapter going down oposite of the oil filter side.
Old Apr 8, 2011 | 02:23 PM
boosted LT1's Avatar
Assuming you aren't running the oil cooler here is one
http://www.hrpworld.com/index.cfm?tp...action=product
or you can simply thread the adapter for pipe thread and place a plug in it
Old Apr 8, 2011 | 02:46 PM
wrd1972's Avatar
Did it to mine too to ensure 100% of the oil goes through the filter.
Old Apr 8, 2011 | 03:13 PM
Big Al's Avatar
Thank you,
Al
Old Apr 8, 2011 | 07:52 PM
fex77k's Avatar
Yea I did it too.
Old Apr 8, 2011 | 08:01 PM
Tbird232ci's Avatar
Now, I'm a bit of a n00b in this department. If the bypass valve inside the part the oil filter threads on to? I ask because I was wondering if it's something I can do on my next oil change.
Man I feel like a dipshit asking a question like this
Old Apr 8, 2011 | 09:03 PM
wrd1972's Avatar
Best thing to do is get a spare filter adapter, mod it then install it on the next oil change. The adapter goes on simply with two bolts.
If you want a spare adapter, I have one for $25.00 shipped. PM me if interested.
Old Apr 8, 2011 | 10:33 PM
James Montigny's Avatar
I run mine the same way. The engine builder suggested it.
He also told me to run NAPA Gold 1060 filter for extra capacity and "anti-drain".
I'm down to one spare Mobil 1 454 filter, so I might try his idea next.
Attached Thumbnails Looking for an easy way to plug the oil filter by-pass.-img017.jpg
Old Apr 9, 2011 | 06:58 AM
wrd1972's Avatar
I wonder how does anti drain works?
Unless I am missing something, I dont see how oil can drain out of the filter unless there is a hole in it.
Old Apr 9, 2011 | 09:15 AM
Yeah, it didn't really make sense to be either.
The anti-drainback valve is usually used on horizontally-mounted filters.
Since ours screws in from the bottom, it should hold oil (but not pressure) even when the pump is off.
I have not found any con to using it though.
I was mostly interested in the extra oil capacity
