no communication
Old Apr 14, 2011 | 04:27 PM
96TransAmboosted's Avatar
Shoe i thought it said 93 so you are correct about 94 DONT flash codes....
95chevyz28- once you use up datamaster you caint uninstall and re install it you must purchace it once the 20 times is used.
Old Apr 14, 2011 | 06:25 PM
shbox's Avatar
You thought what said 93? The OP has a 94 in his sig. Yes, I am correct that you cannot flash codes on 1994 and later LT1s.
Old Apr 15, 2011 | 07:42 PM
95chevyz28's Avatar
Ah. I thought I read somewhere that you can uninstall it and just re-install it. My apologies, I stand corrected...
Old Apr 15, 2011 | 10:36 PM
TransAmdriv3r's Avatar
okay I got a cable and got tuner pro, its free and supposed to be pretty good. if that dont work try datamaster
Old Jun 9, 2011 | 02:29 PM
Bomber Z's Avatar
I'm having the same problem. I used different scanners, and still getting the same. The car sat for a year or so, with running it every other week. This is really pissing me off..
Old Jun 13, 2011 | 10:33 PM
Jeepinstano's Avatar
Any news on the "not communicating"? I have a LT1 94 vette pcm that has been flashed and wired for stand alone and it runs for 3 seconds then dies. But it wont talk to a scanner, I have tried 2 different scanners.
Old Jun 14, 2011 | 06:31 AM
95mysticta's Avatar
Ive had some issues in the past with certain scan tools not being able to communicate but the car runs a1. It was pretty bad though we were using one of those super expensive scantools and it wouldnt read and then we use a cheaper one and she reads no problem.
Old Jun 14, 2011 | 08:02 AM
I have tried the auto x ray and a matco-determinator (I think) both w/ no results.
