So what mods to do (budget)
1)I am thinking of pacesetter LT with ewp and xpipe, sound system, optima battery
2)another route is ss hood and c6 z06 rims oem wheel
3)Another would be pacesetter
ewp
tq arm
tstat
hyper tech
top dash
4) tq converter
then after your first set of mods for this amount, what would u do after it with same amount like the next time around ?
2- long tubes
3- lca relocation brkts
4- new lca's or box the stock lca's
5- a good set of rubber
In that order until the money runs out.
stay away from hypertech if at all possible.
How much power / speed are you rreally gonna gain with a few minor bolt ons.....
But you can look real good real fast................
What tq converter good, my goals is to do ss clone but with c6 black rims, some sound , as for engine I want decent power to be able to beat friends c5 with just borla xhaust; until I figure out what I really want to do with engine Im thinkin ls1 spawp.
I already have straight pipes from stock exhaust mani that why I want headers and it has decent tires on the ss rims, I can wait for rims and hood.
Beating your friends c5 with exhaust is an easy fix. Spray it. 100 shot will had him his *** to 100 mph. Then you can decide what go do with the last 600$.
I can wait for exterior / interior
Its mainly up between suspension with power , a little between everything and or power and sound with a tq arm or lca
Pacesetter lt 300
h pipe 125
system run about 500
then lca or tq arm between 100 -250
i want a good bang for buck
Pacesetter lt 300
h pipe 125
Look on craigs list and ebay for lca's and tq arm. Don't rush. These are two parts that don't break so there is no need to not be patient and save $50thingsep is one of those things
Ewp is one of those things that are only for that last few hp and kind of a waste unless you are already replacing your water pump.
The rest of the money I would either save for the next round or use it to buy all the maintance items(plugs, wires, filters, fuel pump)
You have alot of things you can spend money on, but....if you use your head and make a realistic game plan you'll save a ton of money by not buying th same parts 4 times over like most folks do.
Before you go getting twisted though, ls1 cars are great......but if you think about it. A h/c/I ls1 (streetable cam ) will make ~460 rwhp. Same setup lt1 will see ~430 rwhp. So yea if you think that the extra 3k you spend on the ls1 to have 30 more rwhp then I think you have your wires crossed.
Truth is truth......stock to stock and cai/ exhaust vs cai/exhaust yes a ls1 will own it. But once you crack the valve covers all bets are off. Oh and ill even wager that if you take an ls1 and maim it by removing the factory 1.7 rockers and give it 1.5 like the lt1 you would see and very eerie result(lt1 ftw).
Ok. Im done.
Take it easy, fanboy,
