Plug Question
Old Apr 9, 2011 | 01:01 PM
93BlackZ28's Avatar
Default Plug Question
Just picked up some NGK TR55's and was wondering what I should gap them to? Cam only car with your normal bolt ons. 226/232 .592/.592 110lsa cam. HP #'s in my sig.
I don't know a whole lot about spark plugs so any help would be appreciated.
Old Apr 9, 2011 | 01:24 PM
96TransAmboosted's Avatar
.50 NA about .35 nitrous it what i have always run since the old L98 motors, and all my LT1's
Old Apr 9, 2011 | 03:07 PM
93BlackZ28's Avatar
Thanks. Anyone else?
Old Apr 9, 2011 | 03:56 PM
918_ws6's Avatar
same
thats a safe number
Old Apr 10, 2011 | 04:03 PM
LigHtEmUp01's Avatar
.50 and make sure they are all the same they can be off a little as long as they are all the same gap
Old Jul 20, 2015 | 08:28 AM
93BlackZ28's Avatar
Bumping my old thread to ask OPINIONS on what plugs to run. I'm doing a OTVC kit soon and I'm going to change out the plugs. Should I go back to stock? Is there any real benefit for me to run anything else? Maybe a TR6?
Old Jul 20, 2015 | 03:18 PM
93M6Formula's Avatar
Are you still on stock compression? If so, leave TR55s in there, they work great in my cam only setup gapped at 0.045. If you bumper the compression over 11:1, then i'd go TR6.
Old Jul 20, 2015 | 03:22 PM
93BlackZ28's Avatar
Yeah still stock compression. Do you think there is much of a difference between the TR55's and factory Delco plugs? NGK's are cheaper so I'll probably get a new set of those.
Old Jul 20, 2015 | 05:45 PM
warriorcustoms's Avatar
For a .035 gap TR5 NGKs or R44LTS for A/C Delco on the bottle & if your off gap em to .040 or .045 I went with the R44LTS plugs after a set of TR55s fouled out with a Fat condition I had to chase down... Biggest reason I went with those is the NGKs that were in stock had the screw on caps instead of solid ones... The TR55s were factory gapped at .065 & in My opinion thats harder on the Ole Opti!!!
