7qt pans..
Old Apr 10, 2011 | 07:42 PM
confuzzled's Avatar
Default 7qt pans..
I have a canton fot my 383 turbo car but is there any others out there that are slightly cheaper??? I need one for the 350 nitrous car now...
Old Apr 11, 2011 | 06:48 AM
SS RRR's Avatar
Village Troll
Why not use stock with a better windage tray?
Old Apr 11, 2011 | 07:47 AM
96TransAmboosted's Avatar
Buy a used one. Post in the WANTED section im sure someone out there has one and needs money
Old Apr 11, 2011 | 10:44 AM
confuzzled's Avatar
SS RRR- i would but my stock pan wont clear the melling oil pump i just put in.
Old Apr 11, 2011 | 03:29 PM
95z28_m6's Avatar
I was looking at this. http://www.summitracing.com/parts/HAM-1098/ The only thing is there is no low oil level bung. I'm not to crazy about red but it should work.
Old Apr 11, 2011 | 03:45 PM
merim123's Avatar
ebay $90 http://cgi.ebay.com/ebaymotors/SBC-C...item4cf44ff15c
Old Apr 11, 2011 | 06:07 PM
The only thing im going to say abut the summit and ebay pans are that you get what you pay for. If the pan does not seal good its a PITA to remove it in car and reseal or replace what ever is the issue. I bolted my CANTON pan on with my stock rails and dont have one complaint. Ebay LMAO if you buy from there and summit well the last time i bought there brand anything my car would not fire cause the digital ignition box crapped out on me 7 times! MSD never one issue. just an example i had in my experiance
Old Apr 11, 2011 | 06:46 PM
GREGG 97Z's Avatar
Originally Posted by merim123
Do they just use a stock pan and add the boxed section to it? Thats what it looks like, not sure thats such a bad thing (for the price) just curious if thats what they're doing. Anyone using one of these?
Old Apr 11, 2011 | 09:41 PM
95z28_m6's Avatar
x2 on the Ebay pan, but the link to summit I listed is not a "summit" Pan. I have heard good things about the economy series 7qt pan from Hamburger's Performance. Sure its no Canton but the OP wanted something less expensive. I cant say from experience if it is good or not but I am thinking about giving it a shot myself.
Old Apr 11, 2011 | 09:51 PM
merim123's Avatar
i haven't tried that pan, i was looking for options too. not sure if you'll have fitment quality.
Old Apr 12, 2011 | 04:02 AM
Turnin20s's Avatar
I have a moroso 7 quart pan on my car. I don't remember the part # but its for 86 and up blocks and has the side kickouts. Tucks up slightly above the factory k member, and now with my UMI k member its slightly lower than the lower bar. Check out my build thread to see some pics of the pan
Old Apr 12, 2011 | 05:29 AM
speed_demon24's Avatar
How do you think canton and the other big names make their pans?
Old Apr 12, 2011 | 06:53 AM
green95vert's Avatar
What I have, fits well.
Old Apr 12, 2011 | 07:17 AM
GREGG 97Z's Avatar
^^^ Never really looked into them, that makes sense though.
Old Apr 12, 2011 | 07:21 AM
SS RRR's Avatar
Village Troll
I'm confused. I didn't think Canton's pans were any deeper than stock? Besides, at least Canton's 242t pan is a 6qt IIRC.
Old Apr 12, 2011 | 07:34 AM
355z28's Avatar
kevko oil pans makes one that works well.
Old Apr 12, 2011 | 09:04 AM
sempire's Avatar
question about the ebay one... is it lower by any chance? i need to make sure i don't have anything that hangs lower than it does..
Old Apr 12, 2011 | 12:14 PM
confuzzled's Avatar
I looked at the Hamburger pans, not to bad but the last one i saw installed had a HUGE gap between the pan and bottom of the timing cover.
I dont feel like having to do a pan with the engine in the car, did that once already and it sucked.
Old Apr 12, 2011 | 12:31 PM
sempire's Avatar
It's that bad? I figured it'd be ok..
Old Apr 12, 2011 | 12:35 PM
quik95lt1's Avatar
huh?? what melling pump u running?? i ran a melling m55hv for a while on a stock pan with no problem........and i ran it with my canton 242t as well just had to change the pickup..........
also yes the canton is a stock depth just with kickouts......and it is a 6qt pan not 7
