My first custom built single turbo lt1
well i used my buddys tuning software about 30 minutes ago, he set the timing down to 22 degrees adv at WOT. no tuning otherwise, just so i can drive it under some boost to get an idea of what this thing is gunna be like, it goes way lean at 4100 rpm so it still needs work but i just got home from racing a 2008 z06, nice guy said it had a lingenfelter stage 3 cam, stage 2 heads, long tubes and full magnaflow exhaust, didnt ask what it made but i pulled 10-15 cars on him!!!!!!!! shifting at 3900 rpm!!! with two passengers in the car, holy **** this thing woke the **** up!!!!! saw 5 pounds of boost when shifting. should have seen his face when i turned into my neighborhood!!!!
wow im so stoked for the dyno tune, was loose till 5th and i let out a bit and got back in it and sealed the deal!!!!
wow im shaking as i type this!!! **** yea!!!!!!
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
wow im shaking as i type this!!! **** yea!!!!!!![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
thanks guys, and i can keep my self collected just its been 6 long painful months of this build and its so awesome to finally get it on the streets
but i got the dyno scheduled for may 6th. i want to put some miles on it first to make sure everything is perfect before we push it to its limits.
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
