95 LT1 cat AIR hose
All that being said, if you capped or eliminated one of the check valves, you could run the other one directly to your cat. You could use the flex line for hooking up gas logs, etc. to do that and bend it and route it any way you wanted to. Or you could ditch the whole AIR setup. If you're using a lot of the LT1 harness, if you leave the fuse for the AIR in, it won't even set a code on a 95. Your choice.
