!!help!!Oil inside Distributor!! and leaky seal!
Old Apr 17, 2011 | 06:22 PM
Zumzero's Avatar
Default !!help!!Oil inside Distributor!! and leaky seal!
Hello,
Well after spittin and spudderin, i found my waterpump to be bad, so when i went to replace i checked the distributor and low and behold, when i took off the unit there was oil all inside the housing where the optical sensor is, and my cap was in pretty bad shape, so i bought an MSD pro bullet cap and rotor.
But my question is, is my optical sensor bad to?! i cleaned up all the oil, i used low pressure air to clean it out and the timing wheel to, its as clean as can be now, im just wondering if i should put it back on with my new cap and rotor? or should i bite the bullet and buy a new opti??? what are the chances of it being bad?
Old Apr 17, 2011 | 06:24 PM
Zumzero's Avatar
oh and yes i replaced all the timing seals, but the one behind the distributor was in the worse shape of them all, i guess thats how the oil got inside?
Old Apr 17, 2011 | 07:25 PM
9transam6's Avatar
In my opinion if there is any doubt just change it. As you know it isn't an easy task getting to it. I would just replace it with the GM factory replacement.
Old Apr 17, 2011 | 07:36 PM
speed_demon24's Avatar
Old Apr 17, 2011 | 07:45 PM
Zumzero's Avatar
Default :d
Originally Posted by speed_demon24
lol really? where do i get that and how do i use it?
Old Apr 17, 2011 | 08:43 PM
9transam6's Avatar
Or yea you could do that. LOL
