What vert for a bolt on LT1 car?
Old Feb 20, 2004 | 09:42 PM
foff667's Avatar
LS1TECH Sponsor
Default What vert for a bolt on LT1 car?
I recommended a 3200-3500 to my friend with a 93 TA 3.23 gears, CAI, LM, !cat, slicks what do you guys think?
Old Feb 20, 2004 | 09:46 PM
Spinner's Avatar
Keep in mind with anything over 3,000 stall, he's going to run into OBD1 computer issues with the stall speed.
Old Feb 20, 2004 | 09:56 PM
foff667's Avatar
LS1TECH Sponsor
didnt realize that whats obd1's problem with higher stall speeds if y adont mind...im not real versed on lt1 cars espeically with a 700r4...btw which he has...guess he was an early car.
Old Feb 20, 2004 | 10:04 PM
Spinner's Avatar
I'm not 100% positive about the 4l60s (700r4) without the electronic control, BUT, with the OBD-1 cars in general, the PCM won't shift when you hit redline with a stall to high. IE: You'll float at redline for one... two... maybe three seconds before it shifts. Something to do with the different inputs from the trans and the motor being drastically different with a real high stall, and the cmoputer not "learning, or reading" if you will, fast enough to compensate. Around 3000 stall seems to be the barrier, the problem is worsened with slicks.
Old Feb 20, 2004 | 10:24 PM
foff667's Avatar
LS1TECH Sponsor
thanks again spinner looks like he'll be going tame then dammit
Old Feb 20, 2004 | 11:06 PM
RacinLT1's Avatar
93's dont suffer from that problem. 93's still use the tv cable.
go for the big converter. 94-95's do t want to shift with anything much higher then 2800 for whatever reasons.
Old Feb 25, 2004 | 02:42 AM
bcioli's Avatar
I jsut got a 94Z and just orderd a TCI 3000-3400 ,
My question is can i change the shift points to make it **** on time
Old Apr 8, 2004 | 12:54 PM
bcioli's Avatar
ttt any help ?
Can i tune it to shift with lt1 edit ?
Old Apr 8, 2004 | 01:48 PM
Vendetta's Avatar
The 93 shouldn't have any problems with it because the PCM does not control the 4L60s shift points.
The 94-97s PCM sometimes has trouble upshifting with a torque converter that has a stall higher than 2800.
I would go with 3000-3200 on a bolt-on 93 car.
If you want to bypass the problem on the 94-97 cars, just get your PCM tuned.
Old Apr 8, 2004 | 02:17 PM
bcioli's Avatar
cool thanx
Old Apr 8, 2004 | 02:38 PM
Vendetta's Avatar
Originally Posted by bcioli
cool thanx
no problem.. got any pics of your ws6? som is my favorite color
Old Apr 8, 2004 | 04:09 PM
BizZzatch350's Avatar
Moderator
I have a 3200 in my 93, its fine, we're still old school with an ECM and a 700R4s. The 4L60 is a 700R4 with an extra check ball and 5 pin case connector. You could put a 5K stall in a 93 and I'm sure it could care less. Your friends car is prety much the same as mine, I have a LM, 3.23s, cold air and thats it, the 3200 worls great. Going to make you want some headers though.
