I hate that #8 plug...
If you arnt bleeding yet, then you arnt doing it right, that much i know is for certain on a plug change for an lt1.
if all else fails, seriously, find someone with girly forearms and long fingers.
EDIT: I did just make some progress though. Reason i couldnt get the boot off is cause it mustve been stuck on there real good, cause i just pulled as hard as i could, and it seperated the wire from the actual boot. But now the boot has come off so i can actually get the socket on there now
I think I've found a new sig quote!!
It's funny because it rings so true!!Also, defaultexistence calling the trick with laying on the intake "the superman"...I love it!!!
But yeah, when I changed mine with stock exhaust, I removed the starter just so I could reach up in there and get the boot off and place the socket on the spark plug. The spark plug socket had a hex-shaped head on top of it which allows you to put a socket on top of it if you want. Then I did the superman and reached down with my rachet which had another socket on it which fit over the end of the spark plug socket, then removed it like that.
Once you are done with this, if you still have some skin left on your forearms that you want removed, change the plug wires.
You will never do it any other way after that trust me.
You can get all 8 plugs out in about 20 minutes. The only one you have to get to from the top after that is #2.
#8 is a walk in the park with no y-pipe. And for re-installation its even faster.
Dont forget to put anti-seize on the damm plugs and dialectric grease on the wire ends...this will prevent things from ever becoming a problem to disassemble again.
You need that y-pipe OFF!....i really dont understand how ALL these "informational" websites....dont make that a sticky.
Anyway your half way done now. But truly the trick is to knock down the ypipe.
I am even considering never getting headers due to the stock manifolds making this so easy once the ypipe is off.
My last spark plug swap took 1hour....and I took my time including dropping the pipe....but yea I did that with air gun.
well I do have an ac delete and egr makes things easierlol.
