LT1 question...
Anyways, not to long ago I got a 93 Z28 m6 and it runs good for the most part. However it seems to be running rich, because at idle I can smell a gas like smell, plus when I let off the gas I get a sort of crackling noise from the exhaust which I'm assuming is unburnt gas in the exhaust. I currently get about 170 miles out one tank of gas.
Does anyone have any suggestions? What could be causing all of these symtoms and how to fix them?
I was thinking it could be the o2 sensors as well...how much would it cost to replace those?
If your O2 sensors are in fact bad, buy some new ones and replace. I dont know your financial situation, but If you dont have the cash right now, you may be able to check for used, low milage O2 sensors here on the forum as a temporary fix untill you can afford new ones.
Here is the link for Autozone O2 sensors, i entered your model and year, so these are correct for your car.
http://www.autozone.com/autozone/par...nsor/_/N-9ixrp
Hope that helps.
