lt1 edit
Old Apr 21, 2011 | 01:34 PM
nater36's Avatar
Default lt1 edit
just received this program and it is completely different than tuner pro obviously... can anyone point me in the direction of how to view in live mode? I know it cant datalog or have heard that
Old Apr 21, 2011 | 01:46 PM
jasonisdn's Avatar
it data logs into a text format. its best to use data master to log.
Old Apr 21, 2011 | 02:00 PM
merim123's Avatar
what do you mean view in live mode?
Old Apr 21, 2011 | 02:06 PM
nater36's Avatar
show rpm, speed, stft, iac, etc... as the engine is running
i have the lc-1 kit, is the logworks software compatible?
Old Apr 21, 2011 | 02:12 PM
merim123's Avatar
hmm, unless there is a new release of lt1 edit software, it cannot data log. i have lt1 edit and it does not do that. lt1 edit can only on read/program your tune on the PCM. To data log/see it live, I use Autotap.
Old Apr 21, 2011 | 02:13 PM
nater36's Avatar
i was debating on autotap... how does it seem to work for you? any troubles?
Old Apr 21, 2011 | 02:18 PM
merim123's Avatar
no issues , my version is from 2002 though and it's still perfectly fine. There may be better stuff out there now, i just haven't had the need to look. If i was doing it again, i'd try to find something cheaper.
I have added all the gauges I need on it and it's easy. Plus it helps that the guy that tunes my car uses it too so I can just get the dashboard config file from him.
Old Apr 21, 2011 | 02:26 PM
nater36's Avatar
hm, ok, i think ill order it
Old Apr 21, 2011 | 02:37 PM
nater36's Avatar
ordered
Old Apr 21, 2011 | 03:28 PM
WhistlingZ's Avatar
From LT1 Edit's web site - http://carputing.tripod.com/9495LT1Edit.htm
Free software:
Once you've got the cable hardware, you will need some free software to check things out. Here are two freeware tools that will help you along
Want to see what your car is doing in real time? Try our free scanner for your car. Download the program, and run it on your Win98/Win NT Pentium 133+ or AMD computer that is connected to your vehicles Diagnostic Connector, and you are up and running. pcmcomm.exe. Here is the user's guide for this software: pcmcomm.html. (here is the readme file for pcmcomm readme.) The free version will only show the current values of these engine parameters on the screen. Want to enhance your scanner by logging your runs?? (Show your friends your top speed, and time to reach it) or display all those pesky Diagnostic Trouble Codes? Go to the order form and place your order for the logging scanner. Here's how you select the data rate datarun and here is a sample output log log_run.txt
Of course, you have to see what is already inside of your PCM. So here is a tool that will let you download the contents of your car's PCM to your PC pcmread.exe. Use this to read out the contents of your PCM. Here is the user's guide for this software: pcmread.txt
Old Apr 21, 2011 | 03:29 PM
nater36's Avatar
have a 96, sry
Old Apr 21, 2011 | 03:32 PM
WhistlingZ's Avatar
have a 96, sry
Works the same, but you need a different cable.
http://carputing.tripod.com/9697lt1edit.htm
Old May 6, 2011 | 12:37 PM
nater36's Avatar
which parameters in lt1 edit shuts off o2s? and egr/air?
Old May 6, 2011 | 02:30 PM
jasonisdn's Avatar
02's will not be needed in open loop. the egr and air are in a drag down menu on the main screen that says "function enable".
Old May 6, 2011 | 02:41 PM
nater36's Avatar
yes i know, but i want my ses light off.. rear o2's
Old May 6, 2011 | 03:25 PM
jasonisdn's Avatar
Rear 02's im not sure. I have some sims for those
Old May 6, 2011 | 03:37 PM
merim123's Avatar
don't have the program at work, but go through the menu's it's not hard to find. I think it's in the emissions area and you have to say does it set SES or not for each sensor. really easy.
Old May 8, 2011 | 07:35 PM
nater36's Avatar
i do not have those options...
nvm, found it but ot does not toggle...
