94 Optispark on a 97?
Old Apr 21, 2011 | 11:48 PM
Stocker94z's Avatar
Default 94 Optispark on a 97?
I have a 94 Z28 and I got a 97 motor and my optispark won't work due to the 97 plug being to short. The little prongs are not long enough to make connection or vice versa. Somehow the prongs are not long enough and I was wondering if anyone makes an adapter that will make the 97 motor work in my 94 car without switching opti's. Any input is appreciated thanks.
Old Apr 22, 2011 | 06:23 AM
RamAir95TA's Avatar
If you're using the vented optispark that came with the 97 motor, you need p/n 12130319.
Old Apr 22, 2011 | 06:52 AM
shbox's Avatar
It also won't work because the 97 motor has no way to drive the 94 opti. The cam gear is different, the cam dowel may interfere, plus the timing cover is different. It's not just the harness.
Old Apr 22, 2011 | 11:09 AM
robsquikz28's Avatar
If you need a opti I have one for a 94. Gm opti $120 shipped...lmk
Old Apr 22, 2011 | 10:17 PM
Stocker94z's Avatar
I went through GM and they gave me what I needed. Thanks guys I should have a first start video tomorrow!
