EWP failure warning thru the tune...
Old Apr 24, 2011 | 05:08 PM
1badzee's Avatar
Originally Posted by LSWHO
Again, how is wiring a warning light easier than the 12 seconds of work changing my tune?
Because you have to understand not everyone has the cable and software to do something like this... It is a lot easier for most people to just wire up a light of some sort. Does not seem practical IMO. Not knocking it though, definitely a neat and original idea.
Old Apr 24, 2011 | 06:39 PM
LSWHO's Avatar
No, i got ya. I understand for most it would be much easier with the light.
But I was told that I should just wire in the light because it's easier after I had already said i already changed my tune... Twice.
I think having BOTH would be a good idea. And having a pump that never fails is ideal! Too bad planned obsolescence is the only way to design parts anymore.
Old Apr 24, 2011 | 06:44 PM
gregrob's Avatar
EVERYTHING needs maintenance, especially race parts.
Old Apr 24, 2011 | 06:51 PM
the_merv's Avatar
Veteran: Air Force
Here's what you do..
Have the Main Bolts & Rod Bolts made in a Fuseable Link style.. that way if it over-heats it just drops the Crank out the bottom of it and saves the Engine..
No worries..
Old Apr 24, 2011 | 06:53 PM
joshh123's Avatar
No worries..
great idea!!!
Old Apr 24, 2011 | 07:57 PM
1badzee's Avatar
No worries..
Good to see you are dropping in on the LT1 section from time to time embracing us with your ideas! How's the G-body going?
Old Apr 24, 2011 | 08:41 PM
the_merv's Avatar
Veteran: Air Force
I've been lingering around..
It's goin..
Old Apr 25, 2011 | 07:02 PM
sweetbmxrider's Avatar
So if the pump fails and you are driving on the highway, what good is a raised idle?
Watch your temp gauge....
Hell, you can probably change when the check gauges light comes on in relation to coolant temp, that should take 10 seconds and you get a light!!
Old Apr 25, 2011 | 09:28 PM
LSWHO's Avatar
Pulled timing is obvious. It's like your motor is down 100hp.
I also don't go on the highway often let alone in my car.
And like I said, the light and the tune make a pretty good combo.
If I knew how to change the check engine light come on for overheating I would do that too. As far as the lt1 PCM goes our ability for tuning like that is nonexistent at least as far as what I've seen.
