This car is really pissing me off
-Blew head gaskets
-Changed head Gaskets...Bad head
-Bought Cam,Heads,Rockers
-Swapped in with new clutch.
-Got a rod know
-Rebuilt engine
-Had trouble getting car to run. Got it running good.
-New clutch slipped due to some oil on the disc
-Swapped clutch disc. Clutch would not release.
-New master/slave
-Turned out disc was bent from the factory.
-Swapped in a whole new clutch.
-Drove car 137 miles only to have the oil pump that I supplied for the rebuild fail out.....Dam Melling
-Bought this engine and swapped cam,heads,and all new gaskets.
-Got everything together and the transmission started making bad noises along with the brand new throw out bearing. Just had that rebuilt. New bearings and stage 2 rebuild.
-Now sitting here with the car still acting up. Tired of working on it and I am ready to sell it.
With the other cars I have bought to drive while this has been down I have $25k in 3 cars. One of those is sold. The stupid honda is on life 11 out of 10. Should have bought that GTO 3 years ago.
ICM is good. Also used my brothers and its made zero change. Valve lash was checked and redone. May have someone come to do the valve lash. Or I may do it again tomorrow.
#37
Yeah your telling me. I am going to redo the valve lash tomorrow and triple check the plug wires. The car idles to good for a crossed/burnt wire. Going to pull all the plugs and check/clean them. Also want to say I have checked the injectors and they are all working. If that does not work I'm done. My parents are probably going to help get it in a shop. I am still probably going to sell it afterwards.
#40
Everyone is always blaming the opti right away... Sounds like a bad miss that culd be from multiple issues at the same time. The plugs and wires. Without the proper diag tools you will be Guessing and replaceing parts and wasting time. First thing is you either need to pull every wire and OHM them, Pull every plug and check them(sometimes they look good and are not) OR get a Kilovolt meter that checks wires and plugs and run the car at idle and see if everything checks out ok, then recheck while someone else brake loads the car at 2000rpm or so with emergency brake on as well and see if all checks out. If you ignition passes and you have not checked Fuel then thats where i would go to next. you keep focusing on rocker arms instead of the entire picture. sounds like you need some help from someone who knows what to do
