efi24x lt1 harness repin with PICS!
Thanks man, I'm trying to get this detailed and cleaned up and accurate. I have a lot more to post and not enough time, but trying to get done in the next two weeks.
If you want to run a double roller chain you have to buy there custom made timing cover that will allow for the doubler roller. You also have to order a crank reluctor designed for a double roller setup over the normal single. You have to run a crank sensor to make this kit work. I have to convert back to a single roller chain as im going to use the stock cover without having to spend 350 on the custom one and there other reluctor which is like 250 iirc. If i had the extra cash i would do it but just cant justify it right now.
c100-c105 = bring fused power from the fusebox (front DS headlight fusebox) basically to the ignition and fuel injectors. that is what has to line up there and that's how you power the coils and injectors plus whatever else GM decided to put on there.
C210-230 - are inside the car and those go to the dash and the fusebox inside the car. I had to modify mine slightly because I was using a 96 harness in a 94 car, but if your harness is the same year as your car, you won't have to change anything there other than making sure the pinouts are ok on the PCM itself. hope that helps.
#32
any pix or wiring changes that you did?
#37
thanks alot for the info merim 123, but let me just get one thing straight, are my original plugs from my 94 firebird lt1 pcm, going to fit the ls1 pcm? of course i have to repin it, and does it matter from what year and model i get the ls1 pcm from?
