Plastic Fuel Tank in 94 F-Body
Internet Mechanic
Yes, you really dont want to try cutting or splitting, I would try solvents and dumping it out and do it repeatededly. As long as the corrosion is not in the acutal fuel, you should be fine. Also if your doing a new pump or even reusing an old one. A new fuel sock.
Otherwise I would take it to a proper shop that can clean and service since if not done right, you can spark a vapor and BOOM!
I found that my 1995 tank is coated with some kind of plastic,...you may find that something else, not attached to the actual tank is corroded, like the fuel filler which I know rust from being closer to the outside enviroment or something on the fuel pump setup,...like I mentioned my 7 year sitting tank was perfect,...the pump assembly, perfect too,...the filler neck/tube, corroded badly.
Having said all that why not just buy another tank,...I see them here for $50 complete?
