Fan Switch mod problems
Old Apr 27, 2011 | 04:30 PM
Xposure's Avatar
Default Fan Switch mod problems
I was having problems with the fans on my 1996 Formula A4 coming on so I decided to try this mod out. I got the fans to come on, one when the car is off and either one or two when the car is running. What I can't seem to do is keep the led lights on. I will flip the switch on and the lights will light up for a split second and shut off. I have tried it twice and both times I get the same outcome. Can anyone help me out here? I am using the cig lighter for both ground and power.
Old Apr 27, 2011 | 04:49 PM
litch2004's Avatar
Do you have the correct diode in place?
Old Apr 27, 2011 | 05:29 PM
shbox's Avatar
Need to know what wiring diagram you followed and what you did.
Old Apr 27, 2011 | 05:36 PM
Xposure's Avatar
https://ls1tech.com/forums/showthread.php?t=1015097
This is the one I followed everything is wired exactly as it should be
Old Apr 27, 2011 | 06:35 PM
shbox's Avatar
Maybe you have your LEDs oriented backwards? Since they are diodes, they must be wired with the correct orientation to work.
Old Apr 27, 2011 | 06:53 PM
Xposure's Avatar
I wired them both ways and both turned out the same
