WTF did the opti just do???
Today the motor started fine then as I was pulling out, it died. Was hard to start but started. Died again then started hard again. I hammered on it in first gear and at 5K RPM the engine just totally lost all power and fell on its face and the tach went to zero. I got out of the gas and it returned to normal. After all this I had a code 16.
I then pulled the PCM fuse to reset the DTC code and drove it hard again. I hit 5K RPM and felt a very slight hesitation. After beating on it some more with several 6K RPM blasts in first, its not losing power or doing anything wierd at all. Maybe its a fluke.
Car idles great and runs great except for this incident. Opti has about 10K on it.
Question.
Is it normal for opti wirdness to happen if you leave the key in the on position for several minutes then try to start the car? Does this definitely sound like an opti related issue?
Question 2
Is this definitely an Opti problem? Fuel pressure is spot on.
Hopefully it blew the moisture out once the motor got hot and its just a fluke.
. not sure if i got water in my intake or the opti, but like i said, i learned pressure washes can go to hell with lt1's.
Reminds me of the old Mallory Unilite BS that 99% of was not true.
Al
Al
Al
Al
Most folks hit a problem that prompts them to expend the labor getting to it and justify a replacement because of the effort. Fouling of water, coolant or oil are the most common reason folks tear it down and replace it. I've seen oil intrusion by the rotor shaft due to a bad or improperly installed seal in the timing cover on both types (vented/non). I've also seen coolant getting in through the seals on the distributor body (water pump leaking on it). Also common to get water intrusion similarly by washing the engine bay, driving through heavy standing water (93-94 cars with the weep holes). I had one go bad by crumbling the shaft bearing and clogging the encoder. If the shutter wheel gets bent enough to touch the body of the encoder, it will create enough heat on the encoder to fry it in a couple of days.
In these cases, the optical encoder isn't to blame and would probably be fine for a lot longer if you could correct the physical cause that 'blinded' it. Problem is, nobody makes a rebuild kit for these. And the internal parts rust and can litter the encoder/shutter wheel interface naturally with age. Cheap knock-offs using imitation encoders may work pretty well for a while. Only time will tell who makes one approching the quality of the Mitsubishi. In the meantime, the normal attrition of intrusion/corrosion will continue to cause the vast majority of problems seen with the opti, regardless of where it came from.
2) By hand, using as little water as necessary. This really goes for any engine. Pressure washing one just isn't wise anytime.
