Hard to shift into 1st, 3rd, 5th, and reverse. Ideas?
Old May 10, 2011 | 11:56 AM
96reddevil's Avatar
Well found out today it wasn't a factory shifter. Its an aftermarket short throw. Parts on it were broke. Not sure what parts. Had to take it to my mechanic because of finals in school, work, and somethings going on in my life, but its getting fixed. Thanks for all the help though! I really appreciate it!
Old May 10, 2011 | 12:02 PM
z_speedfreak's Avatar
Originally Posted by the_merv
A Synchro Ring doesnt cause it to pop-out..worn out Keys & D-ring will cause it to pop-out. A Synchro Ring just matches the free-spinning Gear with the speed of the Input shaft/Counter Shaft at the time, hence the name, and the grinding when it's fucked up, or the Keys & D-ring are worn.
If the Cup is fucked off to the point where it will partially engage Reverse then that is his issue on why it will pop-out..the D-ring & Keys aren't fully locking out to hold the Slider on the Gear. Also there is Metal D-ring & Key Retaining Plate on the back side of the Reverse Slider Assembly, my stock T56 was cracked and that caused Reverse to pop out every now n then cause it wasnt letting the Keys hold the Slider in place.
makes sense, except in my case cause my keys and D-rings were just fine and it didn't grind at all in reverse, it would just violently kick out of gear.. I had to park it on inclines until I had it rebuilt must of just been from the slop in my shifter and cup.. but then I don't get why my reverse synchro was so shot owell
And when did you trade the F-body for a G merv? that thing is sick! makes me miss my old one.. hows your body mounts btw? they were the reason I sold this ->
Old May 10, 2011 | 12:04 PM
cool, glad it was nothing major! do you know what kind of shifter it is?
Old May 10, 2011 | 12:45 PM
96reddevil's Avatar
Absolutely no clue. When I get it back I'll tear it apart to look and see what kind it is, if there is a way to tell?
Old May 11, 2011 | 12:04 AM
the_merv's Avatar
Veteran: Air Force
That's a Aerocoupe..not too common..
I did it this past december..it's a blast..
Old May 11, 2011 | 06:03 AM
yeah I made some $$ on that car but I'm still kicking myself for selling it
