What gaskets to use?
Old May 8, 2011 | 11:33 PM
~BuMps AloT~'s Avatar
Default What gaskets to use?
Hey guys im going to tackle a leak coming from the front of my car. The work will be done on a 383 with a LE 236/242 cam.
I just replaced the intake manifold gaskets and that solved the majority of the leaking problems, but there is still a leak from the front of the motor. Its kinda hard for me to pinpoint where it is coming from exactly so I just want to get every seal that I can together so I will be prepared to fix the problem (I have to drive 2 hours home to work on the car) so i want to have everything together so I dont have to make the trip more than once to complete the task. I do however believe that it coming from the timing cover.
Also where is the most common places up front on LT1s to leak oil?
I am planning on tackling the leak in the next 2 to 3 weeks, so I would just like to know what the best seals to order from summit racing. Part numbers would be a huge plus!
Thanks guys
Devin
Old May 8, 2011 | 11:40 PM
gregrob's Avatar
I like GM gaskets / seals myself. The cheap stuff doesn't hold up very well.
Old May 9, 2011 | 06:35 PM
Arent fel-pros factory gaskets? Any part numbers?
Old May 9, 2011 | 09:00 PM
RamAir95TA's Avatar
Uh, no, factory gaskets are GM brand.
www.shbox.com lists several popular gaskets.
Old May 10, 2011 | 10:27 AM
Thanks Joe
Old May 10, 2011 | 12:06 PM
Project382's Avatar
I believe Victor Reinz made most of the factory (GM) LT1 gaskets. You should be able to order Victor Reinz gaskets from Autozone & Carquest stocks them as the Carquest brand.
Old May 10, 2011 | 11:24 PM
5_LTR_ETR's Avatar
search lt1 gasket kit on ebay. theres a full kit for the front of the motor, all GM brand. makes it easy
Old May 11, 2011 | 07:09 AM
shbox's Avatar
A Fel-Pro timing cover set will have all you need for the timing cover and is inexpensive. Never had any issues with Fel-Pro.
